Better brakes
Discussion in '2nd Gen Tundras (2007-2013)' started by Dgoodin, Jun 30, 2023.
  1. Jun 30, 2023 at 7:24 AM
    Dgoodin
    Dgoodin [OP] New Member
    Derek
    2018 Tundra TRD 4x4
    Looking for experienced opinion for bigger brakes. I typically drive past the suggested posted speed limit. However others in 5:00 traffic highly disagree. Any suggestions? Definitely doing crossed drilled and slotted rotors with at least a 4 piston caliper. I see google pricing from 200 to 500 ish then jump 3,000.
  2. Jun 30, 2023 at 7:28 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Big brake kits are really really really overkill unless you're doing track days or towing 10k+.
    Stainless steel brake hoses, dimpled/slotted cryo-treated rotors, and grippy pads like the EBC yellow, these things will up your braking game dramatically, and the stainless lines will prevent fade from heat.
    BlueCrushSC16 likes this.
  3. Jun 30, 2023 at 8:57 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    around $500 is only rotors and pads. The real big brake kits start from 3k with bigger brake rotors and brackets . Other factors with big brake kits are wheel clearance with the calipers and master cylinder volume vs brakes caliper piston volume. If caliper pistons volume is bigger, you will have to push brake paddle further, which is an ill effect for brakes
