SOS need help with timing belt.
Discussion in '1st Gen Tundras (2000-2006)' started by wildduk, Jun 28, 2023.
  1. Jun 28, 2023 at 6:25 AM
    wildduk
    wildduk [OP] New Member
    Atlanta
    2006 DC 2WD
    I’m just wrapping up my timing belt on an 06 DC 4.7l.
    About to put fan and shroud on and I have 1 bolt left over. Its a long shot but anyone know what this goes to? It a long bolt, 12mm head.
    Going back thru U tube videos now. I hope it’s not too far back
    Thanks
  2. Jun 28, 2023 at 6:30 AM
    It kind of looks like one for the alternator or power steering pump. Did you remove that during your work?
    Jack McCarthy and Sean492 like this.
  3. Jun 28, 2023 at 6:32 AM
    wildduk
    Atlanta
    2006 DC 2WD
    I did. I’ll go check.
  4. Jun 28, 2023 at 6:38 AM
    On mine, alt bolts are more grey or gold.
    The little smooth provision on the end tells me whatever it is, it's intended to insert into the block or something that may be a blind entry. AC compressor, PS pump, maybe? I'm stabbing at guesses.
    But one guess that's on-target: I guess this is why everyone warns to bag and tag your parts when doing this job :rofl:
  5. Jun 28, 2023 at 6:43 AM
    I think that's it. It looks familiar from when we worked on John's truck. We had to unbolt his power steering pump and swing it out of the way to do the alternator I think.
  6. Jun 28, 2023 at 6:44 AM
    I had to loosen my PS pump to get my alternator swapped out, but I didn't take the bolt out fully, so I can't remember if it looks like what's pictured.
  7. Jun 28, 2023 at 7:24 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    It’s a long bolt so might go thru something thick, looks like alternator
    it’s the toes for me!
  8. Jun 28, 2023 at 8:06 AM
    wildduk
    Atlanta
    2006 DC 2WD
    I’ve got it mostly pulled apart again….it seems like the alt. and PS pumps use 14mm bolts. 12mm nuts. I’m at a loss here.
  9. Jun 28, 2023 at 8:27 AM
    I think you're the 3rd person who had a leftover bolt after WP/TB swap recently. 2nd one I've seen where the mystery bolt is long and (I think both) 12mm
  10. Jun 28, 2023 at 8:36 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Are you sure that bolt didn’t go to a puller or other tool you may have used??
  11. Jun 28, 2023 at 8:40 AM
    wildduk
    Atlanta
    2006 DC 2WD
    So the only thing I had not yet installed was the bottom bracket that goes on the AC compressor. The bolt I believe it the top hole in the bracket, the bottom gets a nut.
    I think issue solved…..
  12. Jun 28, 2023 at 9:06 AM
    Go ahead and send a check to @shifty` since he correctly guessed that.
    JasonC., Sunnier and DJenerated like this.
  13. Jun 28, 2023 at 9:09 AM
    Mr Badwrench
    Mr Badwrench New Member
    That looks like it might go to the serpentine belt main idler bracket.
    Not the tensioner, but the idler bracket that supports the fan clutch.
    shifty` likes this.
  14. Jun 28, 2023 at 9:11 AM
    It’s definitely the upper left bolt to the flux capacitor cooling assembly housing. Should be replaced every 10 time jumps or 2 years. Whichever comes sooner. And for gods sake, no anti-seize on it!
    Sunnier and shifty` like this.
  15. Jun 28, 2023 at 9:13 AM
    Mr Badwrench
    I'm going off memory above, but unless it's for your ac bracket, I don't remember any bolts like that being terribly buried.
  16. Jun 28, 2023 at 10:11 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I would go to YouTube, find one of the many relevant videos, then carefully watch the disassembly process until I saw the part in question. Or, go to one of the parts sites and look at the exploded diagrams.
    tvpierce and shifty` like this.
