Lose all power when I turn key to start
Discussion in 'Electrical' started by bhcaz123, Jul 13, 2021.
  1. Jul 13, 2021 at 11:10 AM
    bhcaz123
    bhcaz123 [OP] New Member
    david
    2004 tundra limited
    have 2004 tundra, wont start , new battery , lose all power when i turn key to start , have to reconnect battery to get power again but every time go to try it does it again , have ckecked cables, and c/opn relay , any thoughts
  2. Jul 13, 2021 at 11:20 AM
    timsp8
    NY
    Did you try to jump it? Sometimes new batteries are bad too.
  3. Jul 13, 2021 at 11:25 AM
    bhcaz123
    david
    2004 tundra limited
    tried, same results, one click , all shuts down , reconnect battery , get power
  4. Jul 14, 2021 at 12:59 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I hope someone here can help you with this issue . . .
  5. Jul 14, 2021 at 1:20 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
    Good luck
  6. Jul 14, 2021 at 1:27 PM
    Welcome from NY.
    Could it be the starter or ignition switch?
    NewImprovedRon likes this.
  7. Jul 14, 2021 at 1:36 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome! Hope to hear you figure it out.
  8. Jul 14, 2021 at 2:03 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Test battery, new batteries can be bad.
    check all battery connections at battery
    check grounds
    Follow cables down from battery and check condition, check all starter connections, could be loose and there may be a fusible link somewhere in that run that is bad
  9. Jul 14, 2021 at 7:39 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Sounds to me like something is grounding out when the ignition circuit is made. Welcome from LA (Lower Alabama)!
  10. Jul 15, 2021 at 2:45 AM
    Welcome from Ohio
  11. Jun 28, 2023 at 6:44 AM
    scome
    scome New Member
    Stephane
    Tundra 2011 5.7
    None
    Did you ever find and fox the issue? Just got the same thing yesterday. Battery was super corroded. Got a new one, turn the ignition and I lose all power. No fuse are tripping, but I’m getting a voltage of 2V between the negative terminal of the battery and the chassis. Disconnect, reconnect the battery, start fresh, same thing.
  12. Jan 9, 2024 at 7:08 PM
    gohikeone
    gohikeone New Member
    2000 Tundra Limited 4WD V8
    Hi all...new to the forum. Came to reply here asking (hoping) someone came up with the answer to this. I have the exact same issue...just as described above. Turn the key, power goes out. Pull the battery, wait a tick, reconnect. Power back on. Turn the key...stone cold dead.
    Thanks all...
    Edit: check this thread....seems like someone found an answer for their same problem
    https://www.tundras.com/threads/turn-the-key-and-nothing.125540/
  13. Feb 22, 2024 at 8:43 AM
    Bluey20
    Bluey20 New Member
    2015 Blue Ribbon Tundra SR5
    Did you try the fix in that thread? I’m having g the same issues but it’s super random. Sometimes it starts fine and others it shuts the electronics off. I plan on checking all connections and alternator with multimeter and reporting back
