Water pump leak
Discussion in '1st Gen Tundras (2000-2006)' started by wildduk, Jun 27, 2023.
  1. Jun 27, 2023 at 11:10 AM
    wildduk
    wildduk [OP] New Member
    Atlanta
    2006 DC 2WD
    Doing a timing belt/water on my 06 double cab. Looks like the water pump was leaking a bit. how important is it to get all that red cleaned up?
    I’ll clean the inside of pump area and the gasket surface, but all those nooks are hard to get to….
  2. Jun 27, 2023 at 11:20 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Spray some degreaser/ cleaner solution on there then hose it off. Should come off fairly easy.
    Schcoman and Aerindel like this.
  3. Jun 27, 2023 at 11:26 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    This...
    and a Hard Bristle Toothbrush
  4. Jun 27, 2023 at 1:05 PM
    shifty` Bohannon Bohannon Bohannon Bohannon
    Yup, it's just crystalized coolant. Should dissolve pretty quick.
    Oh - and quick tag to @FirstGenVol ... wonder if you've got similar going on...
