Trail pin stripe help
Discussion in 'Detailing' started by Casper421, Jun 26, 2023.
  1. Jun 26, 2023 at 6:11 PM
    Casper421
    Casper421 [OP] Toyota RidgeTrac driver!
    In the woods
    06 DC
    After 6 years of taking my tundra through overgrown trails it didn’t fit on, I’m looking to give her some attention and try to remove some pin striping. I have a Griots 6” random orbital and some pads it came with. I’m kind of embarrassed to say I’ve never gone above an occasional foam wash with this truck; it’s always been function over form. First off, are these pin stripes something I can tackle or should I just bring it to a detailer next to my shop? Lastly, what would you gurus recommend pad and compound wise if I were to diy it?
    Just a small section but the sides are covered:
  2. Jun 26, 2023 at 8:07 PM
    White 2.5
    White 2.5 New Member
    Mt P, SC
    2020 White DC
    Can’t speak to specifics, as I’m an amateur when it comes to this stuff. But I have found that a clay bar will remove more than I ever expected, beyond that a simple glazing compound will do wonders too with an orbital.
    *Patiently awaiting someone with more experience to chime in…
    Tripleconpanna likes this.
  3. Jun 26, 2023 at 9:13 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    :popcorn:
    I miss the shine of the paint but just curious to see if death by pinstripes can be resurrected.
  4. Jun 26, 2023 at 9:57 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  5. Jun 26, 2023 at 10:08 PM
    AZTundra
    Paul
    Phoenix, AZ
  6. Jun 26, 2023 at 10:15 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think that paint looks salvageable. I did clean up quite a few pinstripes on mine with a DA polisher and some decent compound. It’s a lot of work though. But @BiggHertz puts my buff jobs to shame, maybe he can chime in.
  7. Jun 26, 2023 at 10:15 PM
    Just the tips
    1lowlife, Cruzer, bmf4069 and 3 others like this.
  8. Jun 26, 2023 at 10:16 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just for a second.
  9. Jun 26, 2023 at 10:17 PM
    The ol two buff stuffs
  10. Jun 27, 2023 at 12:14 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If you don't like it we can stop :D
    TRDFerguson[QUOTED] likes this.
  11. Jun 27, 2023 at 3:40 AM
    War Machine
    War Machine SSEM # 5 3MW
    From the looks of that I’m pretty sure you can get almost all of it with the Griots DA.
    I’d first use some Iron X and a clay bar / mitt to decon the paint, then go to town with the DA. Personally, I’d use Uro-fiber pads with a medium grade compound, then follow up with finishing pads and polish. The Griots Boss system of products will handle just about anything.
    https://www.griotsgarage.com/boss-c...MIn9vJ0aDj_wIVv2pvBB1bPAL7EAQYASABEgKHt_D_BwE
    If that doesn’t get it all you can always go back with something stronger, but I’d start with the correcting cream and perfecting cream first. @briarpatch may have other recommendations as well, but in my experience the Griots system is going to be enough for just about anything.
  12. Jun 27, 2023 at 8:26 AM
    Casper421
    In the woods
    06 DC
    I like the sound of that! I’ll grab some some compounds and pads and give her a shot. Appreciate the info!
  13. Jun 27, 2023 at 11:19 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    How many of these can you feel with your finger nail? And has the truck ever been paint corrected?
    Casper421[QUOTED][OP] likes this.
  14. Jun 27, 2023 at 12:32 PM
    Casper421
    In the woods
    06 DC
    Very few can be felt with a finger nail. No paint correction in the 6 years I’ve owned it. Doubt the po did paint correction.
    gosolo likes this.
  15. Jun 27, 2023 at 12:45 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  16. Jun 27, 2023 at 2:52 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  17. Jun 27, 2023 at 3:16 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Sounds like you’ll have some material to work. What are your realistic expectations of the final product?
  18. Jun 27, 2023 at 3:24 PM
    Casper421
    In the woods
    06 DC
    As long as it doesn’t look like my ex’s keyed my truck hundreds of times, I’ll be happy. I know I won’t be able to get rid of everything but any improvement will be worth the effort.
    TRDFerguson likes this.
  19. Jun 27, 2023 at 3:39 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    In that case, i think investing some time into chemical decontamination “fallout remover” followed by mechanical decontamination “clay mitt/bar”, good wash, a single step correction (my preference is sonax perfect finish on a rupes yellow pad), panel prep “ipa wipe”, assess what you need from there, could use a glaze to help fill in some of the deeper imperfections in the clear and top it with a polymer paint sealant.
    This will get you where you need to be without removing too much material.
    Casper421[OP] and TRDFerguson like this.
  20. Jun 27, 2023 at 3:43 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You had me at "ipa wipe asses"
    T-Rex266 and BiggHertz[QUOTED] like this.
  21. Jun 27, 2023 at 3:46 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I’m not even mad…
  22. Jun 29, 2023 at 4:59 AM
    I agree with the others. Those scratches should buff out. Also, if you don't have a ton of experience with clay bars, they make clay mitts now that can be easy to use. Less change of dropping them on the ground.
