Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Jun 24, 2023 at 10:42 AM
    #1231
    SAGE63
    San Diego County
    hope it holds
    Cruzer[OP], eccracer104 and Blang805 like this.
  2. Jun 24, 2023 at 3:26 PM
    #1232
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Was in the garage and found this
    Fawwwwk! I put the wrong balance beads in the bead grip wheels :facepalm:I have to go back to the shop, pop the impossible bead, and throw these in there.
    Mater likes this.
  3. Jun 24, 2023 at 3:27 PM
    #1233
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    OOOOOOOOOOOPS
  4. Jun 24, 2023 at 5:47 PM
    #1234
    Cruzer
    Cruz
    Sunnyvale, CA
    I think I’ll try feeding it through the valve stem.
  5. Jun 25, 2023 at 6:50 AM
    #1235
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    What beads did you use ?
    We used to use airsoft beads and never had any issues.
  6. Jun 25, 2023 at 10:40 AM
    #1236
    Cruzer
    Cruz
    Sunnyvale, CA
    I’m using glass beads cuz they’re not affected by moisture, they’re more dense so they take up less space, and they won’t melt or lose their special coating if I use a flammable spray to pop the bead back on.
    Sunnier likes this.
  7. Jun 25, 2023 at 12:30 PM
    #1237
    SAGE63
    San Diego County
    So what did you put in....that were not the balance beads
    rockmup likes this.
  8. Jun 25, 2023 at 1:36 PM
    #1238
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That sounds like a lot of effort to fix something that won't make a difference.
    Sunnier likes this.
  9. Jun 25, 2023 at 8:30 PM
    #1239
    Cruzer
    Cruz
    Sunnyvale, CA
    Literally took all day to install the glass balance beads through the valve stem. They’re like a 1/3 the size of BBs for an airgun so I figured they would go right in the valve - nope. Of course they like to get stuck.
    Drove her on the freeway at 80mph and no out of balance vibrations :D Although I could feel each knob of the tire when I go slow. Have I mentioned that these tires are loud AF? Crazy loud but I like it. The knobs on the tire are so big that I now rub on the body mount at full lock.
  10. Jun 25, 2023 at 8:32 PM
    #1240
    Cruzer
    Cruz
    Sunnyvale, CA
    I bought a ceramic set and a glass set of beads. The ceramic set came in 2 different size bags. I put the smaller of the two bags in the tire.
    SAGE63[QUOTED] likes this.
  11. Jun 25, 2023 at 8:54 PM
    #1241
    snivilous
    SW UT
    Curious to se how you like them. Wheeled with a heep over the weekend that had them and was extremely unimpressed, but the whole rig was unimpressive so maybe that was the real issue :rofl:
  12. Jun 25, 2023 at 9:02 PM
    #1242
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Truck looks good'm mean with those tires
    SAGE63 and Cruzer[OP] like this.
  13. Jun 26, 2023 at 10:27 AM
    #1243
    Cruzer
    Cruz
    Sunnyvale, CA
    Drove the truck to work in order to get some miles in so that I can re-torque the drop bracket and everything else I took apart. I was surprised that the tires felt lumpy from what I guess the truck being parked overnight and tires developing a flat spot. Once I drove it a little the flat spots disappeared. I was also surprised that my alignment was still spot on. These tires don't wander around the lane like my road tires do so that's definitely a plus. I'm not liking the rub though. The knobs on the outer edge of the tires really do stick out far. When feasible I do plan to trailer these wheels to the trails in one of those small enclosed Uhaul trailers and do a wheel swap at main camp.
  14. Jun 26, 2023 at 12:09 PM
    #1244
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Your truck is so big it makes it look like you bought a tiny house from discovery network :rofl::rofl::rofl:
  15. Jun 26, 2023 at 12:16 PM
    #1245
    Cruzer
    Cruz
    Sunnyvale, CA
  16. Jun 26, 2023 at 9:01 PM
    #1246
    Cruzer
    Cruz
    Sunnyvale, CA
    Had to drive the truck around at 55 or less for an extended period of time and it sucked. I knew going in that the tread on these tires are so aggressive that my ride was gonna suck. The balance beads work really great at 65+ but below that these tires feel like a yellow brick road. I can’t tell if the rotation is too slow for the beads to work or if the knobs on the tire are just too chunky. Either way I’m not happy with the on road performance of these tires, which was expected cuz I bought them for off road use only. Can’t believe I’m saying it but I can’t wait to put my street tires back on :rofl:
  17. Jun 26, 2023 at 9:27 PM
    #1247
    SAGE63
    San Diego County
  18. Jun 27, 2023 at 4:38 AM
    #1248
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Badass
  19. Jun 27, 2023 at 9:20 AM
    #1249
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Just drive >65mph everywhere. Problem solved. :burnrubber:
  20. Jun 27, 2023 at 1:19 PM
    #1250
    Cruzer
    Cruz
    Sunnyvale, CA
    daveeasa and CaptRussia253 like this.
  21. Jun 28, 2023 at 7:25 PM
    #1251
    Cruzer
    Cruz
    Sunnyvale, CA
    Holy shit I was randomly searching for Tundra transmission parts and this popped up. I immediately snagged their only one. Been looking for a long time for this output shaft cuz I need it to get a spline adapter made.
    :yes:
    Now to find a used transmission tailhousing on the cheap.
    snivilous, rockmup, Sunnier and 6 others like this.
  22. Jun 28, 2023 at 7:33 PM
    #1252
    Cruzer
    Cruz
    Sunnyvale, CA
    Whaaaaat?! Today is my lucky day. $250 for this fucker is the cheapest I've found. Sold!
  23. Jun 28, 2023 at 9:04 PM
    #1253
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    Did you buy a lotto ticket also ?
    :devil:
    snivilous, Gaston, Cruzer[OP] and 2 others like this.
  24. Jun 30, 2023 at 9:02 AM
    #1254
    Djayyykiddoh
    Djayyykiddoh New Member
    Deej
    Eastvale CA
    2021 WCP Tundra Platinum
    Damn this looks good. :O
  25. Jun 30, 2023 at 9:14 AM
    #1255
    snivilous
    SW UT
    If you need some design work, sniv speed shop is available :D
  26. Jun 30, 2023 at 9:19 AM
    #1256
    Cruzer
    Cruz
    Sunnyvale, CA
    Design? :monocle: I know I need a spline adapter made if you could help with that :cool:
    Sunnier and snivilous[QUOTED] like this.
  27. Jun 30, 2023 at 9:25 AM
    #1257
    snivilous
    SW UT
    Only prerequisite is you have to invite me next time you're in Utah :p
    But for real, I'm down to help since it's a sweet project. Between the spline adapter and if you're planning to run an adapter plate between the trans and atlas, you might need a bit of CAD work. Also that machinist I use that I sent the contact info for, as I recall I've seen him machining splines. Which on that note, regardless who you have machine the spline adapter it'd probably be a good idea to send the spline ends to the machine shop so they can verify the fitment before sending it out, since there's quite a few variables when it comes to splines and would suck to receive the part and have to send it back if it didn't engage properly. Food for thought.
    Mater, ATV25, Sunnier and 1 other person like this.
  28. Jun 30, 2023 at 9:08 PM
    #1258
    Cruzer
    Cruz
    Sunnyvale, CA
    Are you able to measure the spline angles? I have no clue on the terminology and stuff. Gonna reach out to your guy.
  29. Jun 30, 2023 at 9:45 PM
    #1259
    Cruzer
    Cruz
    Sunnyvale, CA
    So I put my 39" street tires back on. I had the shop put the ceramic balance beads on the front tires only. One tire still had the counter weight, while the other tire I took off the counter weights. Pre-balance beads, 75mph I would still feel an uneasy vibration. Post-beads, shit is buttery smooth at all speeds. I did 55mph for an extended period of time and had no problems. Did 90 and it was a smoooooth criminal. Quite happy and at ease with these street tires now. Ever since the tire launching incident I've been paranoid AF.
    So my take on balance beads is that if you're tires are NOT meaty, then it'll probably work. Driving down to SoCal this weekend and really don't want the :ballchain: to experience a tire launch cuz that'll be the end of my wheeling career :rofl:
    helidave, snivilous, Sunnier and 4 others like this.
  30. Jul 1, 2023 at 10:45 AM
    #1260
    snivilous
    SW UT
    If you measure the minor diameter, major diameter, and distance between the valleys of the splines that will tell you the angle. Spline angles are usually pretty common and either 30deg or 45deg.
    Cruzer[QUOTED][OP] and 831Tun like this.
