Differential spool
Discussion in '2nd Gen Tundras (2007-2013)' started by 08CM4x4, Jun 21, 2023.
  1. Jun 21, 2023 at 6:40 PM
    08CM4x4
    08CM4x4 [OP] New Member
    Any you guys go fully locked with a spool trying to find one but not having any luck. Trying to look at other 10.5" rear ends ford/Chevy but all seem to have diffrent bolt patters
  2. Jun 21, 2023 at 6:56 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Don't think I've ever seen one for a Tundra.
  3. Jun 21, 2023 at 7:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wish powertrax made a lunchbox locker
    08CM4x4[OP] likes this.
  4. Jun 22, 2023 at 6:16 AM
    08CM4x4
    That would be perfect
  5. Jun 22, 2023 at 7:33 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Haven't heard of a spool for the tundra. Just weld the diff :D
    08CM4x4[OP] and KNABORES like this.
  6. Jun 23, 2023 at 7:46 PM
    Dr_Al
    Dr_Al New Member
    Al
    I think your only option is an air or E locker if you want something more than limited slip. I guess you could call up a company like USA Standard Gear or Nitro and ask how much they would charge to make one. They should be able to, it just might cost more than the options already available.
  7. Jun 26, 2023 at 12:21 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Does anyone have some detailed specs on the gear size and carrier size, number of ring gear bolts?
    OS-Giken Superlockers are available for many Toyotas but I don't see our Tundra listed.
    There plenty less expensive lockers out there from US distributors.
    I'll start a list of distributors to call.
    https://osgikenusa.com/collections/lsd
