2021 Double cab limited Shock question
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2wheeledfaith, Jun 13, 2023.
  1. Jun 13, 2023 at 7:02 AM
    2wheeledfaith
    2wheeledfaith [OP] New Member
    Not planning on doing a lift but occasionally have to carry heavy loads. I have airbags but the stock black rear shocks need replacing. Considering the Bilstein 5100 shocks but would like to consult those of you who are much more knowledgable about best applications for this than me. Will also be replacing front coil overs too. Most likely with stock springs. Not looking to lift it nor am I planning on doing any off road other than normal dirt roads. Typically do all my own work and service but want to be sure of the best application for the shocks.
  2. Jun 13, 2023 at 7:22 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    If you’re not looking to lift the truck Bilstein 4600’s are a better bet. They improve towing and carrying weight performance. However the are on the firmer side. Do not confuse the Bilstein 4600’s with the OEM TRD Bilstein’s as they are not the same shock.
    I have run multiple setups in various Toyota trucks with different sag aids (Timbrens/airbags/etc). Personally, since you already have airbags, just pick a comfortable shock (OEM Bilstein/Eibach) because a firmer shock + airbags make for a shitty ride unloaded. Airbags allow for fine tuning which IMHO negates need for a heavier dampened shock (unless the bed is under constant heavy load-different convo though…).
    2wheeledfaith[OP] and 1lowlife like this.
  3. Jun 26, 2023 at 6:51 AM
    2wheeledfaith
    Thanks for the input. I put the 4600's in the rear and couldn't be happier. I have ordered them for the front. My stock rear shocks were shot and I'm sure the fronts are no different. Thank again Oey12
    Oey12 likes this.
  4. Jun 26, 2023 at 7:40 AM
    Check out the Roadmaster Active Suspension as an option for the rear weight support.
