Blank switches with plugs behind them, 1794
Discussion in '3rd Gen Tundras (2022+)' started by DexterL, Jun 23, 2023.
  1. Jun 23, 2023 at 2:33 PM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    Was swapping out some stuff today and noticed I had 2 wiring harnesses with blank plugs on my 1794 TRD off-road. Anyone know what these 2 plugs are for? My truck has pretty much every option but the electric running boards and tow mirrors. Thanks!
  2. Jun 23, 2023 at 2:41 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Try looking for a switch panel on a different truck and see what switches are there that you don't have. I know on my 2020 I had a similar plug and it was for the alarm system glass break.
  3. Jun 23, 2023 at 3:06 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Platinum here
  4. Jun 23, 2023 at 3:10 PM
    DexterL
    Bottom one is for the electric running board auto off/ on it looks like, other one must be toe mirrors??
    pwpblue[QUOTED] likes this.
  5. Jun 23, 2023 at 3:23 PM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    They are for the outer mirror light switch and outer mirror extend switch (tow mirrors)
    ryanwgregg and pwpblue like this.
  6. Jun 23, 2023 at 3:25 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
  7. Jun 24, 2023 at 1:50 PM
    DexterL
    makes total sense. Looks like tow mirrors would be plug and play then on my truck vs the folks that have gone through hell and back trying to make em work
    iiawah808 likes this.
  8. Jun 24, 2023 at 8:35 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Noticed the same while I was digging around back there. A pigtail from the wiring harness is terminated into each blank. My 22 Limited non-HV does not have the heated steering wheel, inverter, or tow mirrors so I was a little surprised to see all the wiring there.
