Let's Talk Knives
Discussion in 'Off-Topic Discussion' started by nk1794, Jan 28, 2018.
  1. Jun 18, 2023 at 6:13 AM
    #3421
    RobertD
    Robert
    DFW, Texas
    @gosolo when are you going to start making yours in gold??? :rofl:
    Currently there isn't much info on this knife except they say the blade is "Gold Damascus" which is super helpful in knowing if this is a joke or a decent knife.
  2. Jun 18, 2023 at 7:16 AM
    #3422
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Maybe gold plated, but gold is too soft of a metal to be a full blade on its own.
  3. Jun 18, 2023 at 7:45 AM
    #3423
    RobertD
    Robert
    DFW, Texas
    That's why I'm curious what it's blade comp is
    gosolo and jewsNbrews[QUOTED] like this.
  4. Jun 18, 2023 at 8:37 AM
    #3424
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There’s considerable effort in Pakistan, China, Taiwan and other places where labor is cheap, recycled junk metals are plentiful, and zero environmental concerns exist, to produce junk knives like these IMG_0121.jpg
    The usual method is to use an etching template and then color the surface with a coating. Obviously it’s not pattern welded Damascus.
    on the other hand, there are custom knife makers that are making true pattern welded Damascus that incorporate nickel, copper, titanium, stainless steel and other materials in the layers to create outstanding contrasts and colors.
    These are some beautiful pieces but in some cases are not as strong.
  5. Jun 18, 2023 at 8:56 AM
    #3425
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    in this blade, the outer 2 layers are 455 layer Damascus with another 2 layers of pure nickel sandwiched on each side of a core layer of high carbon steel.
    The key to making this an effective blade is to make sure that the softer material doesn’t reach the edge
  6. Jun 18, 2023 at 9:39 AM
    #3426
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Come on everyone needs a pocket cleaver :crazy:
    gosolo likes this.
  7. Jun 18, 2023 at 11:08 AM
    #3427
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Some gcarta inlays I did on my jCape
  8. Jun 18, 2023 at 11:20 AM
    #3428
    cctxquicksand
    This looks like mokume gane rather than Damascus, essentially just Damascus with non irons. Rays please correct me if I’m wrong. Terrible for a blade, great for accents! I’ve got a cleaver otw with mokume I believe they are using brass copper and nickel. It’s tricky because the low melting points. You can do something pretty similar with a stack of quarters
    gosolo likes this.
  9. Jun 18, 2023 at 11:29 AM
    #3429
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm waiting for 'Diamond Damascus' :muscleflexing:
  10. Jun 18, 2023 at 5:58 PM
    #3430
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I don’t believe it’s mokume at all. Just a cheap imitation with no layers. If I had the name of the seller I’d be happy to research the details. My guess is that it’s cheap carbon steel, like the stuff used for grade 40 rebar. Perhaps drop forged or maybe stamped. Then a stencil attached to get a pattern, when submerged in an acid. After that, the stencil could be removed and the color applied.
  11. Jun 20, 2023 at 7:14 AM
    #3431
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  12. Jun 20, 2023 at 8:41 AM
    #3432
    RobertD
    Robert
    DFW, Texas
    I'm curious what the 8 rules are that are more important than having a knife.
  13. Jun 20, 2023 at 9:05 AM
    #3433
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Just the usual stuff about shelter, water, food and guns…
    Tripleconpanna and jewsNbrews like this.
  14. Jun 20, 2023 at 9:16 AM
    #3434
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    See below :D
    Per Gibbs
    gosolo, bulldog93, JMB and 3 others like this.
  15. Jun 20, 2023 at 9:34 AM
    #3435
    RobertD
    Robert
    DFW, Texas
    Goddness, I forgot about the NCIS rules to live by. Been awhile since I watched that. Thanks!
    @gosolo fair, thanks!
    gosolo likes this.
  16. Jun 21, 2023 at 7:38 PM
    #3436
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Finally finished the set of 3 neck knives! These little sheaths were a bit of a challenge. I can’t wait to see pictures of the girls that are going to get them as gifts!IMG_0157.jpgIMG_0158.jpgIMG_0156.jpgIMG_0159.jpg
  17. Jun 21, 2023 at 7:52 PM
    #3437
    Blue Thunder
    Washington
    Absolutely stunning my friend. Well done
    JMB and gosolo[QUOTED] like this.
  18. Jun 22, 2023 at 10:02 AM
    #3438
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Hurrah!! Done with sheaths for a while, now it’s back to the “daily grind”IMG_0160.jpgIMG_0164.jpg
  19. Jun 22, 2023 at 10:24 AM
    #3439
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Very nice Ray!:)
    gosolo likes this.
  20. Jun 22, 2023 at 6:29 PM
    #3440
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I was trying to get a visual representation of the pattern in the wood grain with the design embossed in the sheath. I toned down the blue color with the addition of about 40% black. Definitely didn’t want the 2 blues to match.
  21. Jun 23, 2023 at 5:09 PM
    #3441
    Musicmasterd12
    Southern Louisiana
    Decided to pickup the Boker plus strike to go along with my mini and stubby.
    I think this one is the best quality. The safety has a nice click when engaging it, seems a little snappier than the mini but not quite as much as stubby.
    Honestly if I would’ve picked this one up before my benchmade claymore I may have not gotten the claymore, b/c for $70, roughly $200 cheaper than the claymore, I think it’s a solid buy! Although the claymore is definitely built better since it’s sharper and the blade seems of higher quality
    Size wise I like the Boker mini strike the best.
    I feel like the plus and claymore are a little big for my shorts pockets at times. Now I’ve discovered they make a claymore mini so thinking I may end up with one of those in the future as well!
    I don’t have a spectacular knife collection, but you gotta start somewhere :D
    Oh yea and here’s a pic of a little something the wife threw in the bag of Father’s Day stuff
  22. Jun 23, 2023 at 5:13 PM
    #3442
    RobertD
    Robert
    DFW, Texas
    They make a Claymore mini?!?!?! :goingcrazy::lalala:
    Hightide, gosolo, Prostar 190 and 4 others like this.
  23. Jun 23, 2023 at 5:16 PM
    #3443
    Musicmasterd12
    Southern Louisiana
  24. Jun 23, 2023 at 5:17 PM
    #3444
    RobertD
    Robert
    DFW, Texas
    gosolo likes this.
  25. Jun 23, 2023 at 6:26 PM
    #3445
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Sure does look like a good start on a fine collection!
  26. Jun 23, 2023 at 6:35 PM
    #3446
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    A leo friend, local sheriff deputy, wants me to make one of these from Damascus IMG_0168.jpga bit of a challenge. I told him that without the molded scabbard it wouldn’t be possible, so he gave me the whole thing.
  27. Jun 23, 2023 at 8:23 PM
    #3447
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That thing in RT Damascus is going to be nuts
  28. Jun 23, 2023 at 8:43 PM
    #3448
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Love this 940
  29. Jun 26, 2023 at 7:06 PM
    #3449
    cctxquicksand
    Moving a few if anyone is interested
    thought I would give you boys first dibs
    all users, I will sharpen all prior to shipping
    detailed videos are available if anyone needs
    zt0462 ti/cf - 275
    Zt0462 tan - 240
    Zt 0909 130
    Zt0801ti 150
    Zt 0562ti 250
    Bugout 115
    Mkm Vincent 80
    Civivi elementum 50
    all obo
  30. Jun 26, 2023 at 7:13 PM
    #3450
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Marriage knives. WoT nerd reference.
    gosolo[QUOTED] likes this.
