Traction Control light on with nothing else
Discussion in '2.5 Gen Tundras (2014-2021)' started by drpheta, Jun 23, 2023.
  1. Jun 23, 2023 at 4:31 PM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    What could be causing this light to be on and not flashing?
  2. Jun 24, 2023 at 6:10 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You may need to recalibrate your yaw sensor/controller...for my experience, my 4runner did this after a lift and it just needed calibrating...was a 5 min task...I'm not certain how it's done on a tundra tho...
  3. Jun 24, 2023 at 6:15 AM
    drpheta
    That stinks. I wonder if it's related to having the battery unplugged for 2 days while I had my steering wheel off to install the leather wrapping.
    HulkSmurf14[QUOTED] likes this.
  4. Jun 24, 2023 at 6:24 AM
    HulkSmurf14
    2014 Tundra Limited
  5. Jun 24, 2023 at 7:13 AM
    HulkSmurf14
    2014 Tundra Limited
    I'd suggest it's due to the steering wheel being off...all good though as it us an easy fix...
  6. Jun 24, 2023 at 9:19 AM
    drpheta
    Did the reset, but now the TRAC, ABS, and Brake light are all on.
  7. Jun 28, 2023 at 6:41 PM
    drpheta
    Picked up an Autel scanner to best diagnose and service this truck w/o having to deal with hack-a-laptop for Techstream (also want to program keys in the future, as well). Got to troubleshooting the SAS, and couldn't get a reading on it whatsoever. Took out the ribbon cable/SAS module to see if it might be anything funky. Cleaned the contacts, checked the cables, no fuses blown anywhere under dash or hood. All seemed fine, and was about to order a new SAS module. Plugged it all back and ran the Autel again and it got a reading from the SAS.
    *shrug*
    Reset the YAW and SAS controller like linked above, all codes cleared. I have no idea what the hell happened, but I'll take it.
    texasrho83 and HulkSmurf14 like this.
  8. Jul 13, 2023 at 6:17 PM
    eowade
    eowade Restore The Republic!
    Eric
    2019 Voodoo Blue Tundra TRD Pro
    Smittybuilt 10klb winch, 295/70/18 Recon Grapplers, Remote Start, WeBoost, Mifi, Philosin 13.3 inch rotatable HU, Center Console wireless charger, Nilight hood, ditch, and bumper lights on 8-gang switch
    It could be as simple as a need to make sure your fuzes (under the hood) are fully seated, and facing the right direction (yes, it really does make a difference).
