Pro-Comp long travel
Discussion in 'Long Travel Suspension' started by Joaopac, Feb 10, 2021.
  1. Feb 10, 2021 at 8:43 AM
    Joaopac
    Joaopac [OP] New Member
    16 platinum Crewmax 4x4
    3,1
    Hello all, has anyone ever installed the pro comp long travel kit on their tundra? Or heard anything from anyone? I found one that I might jump on but was wondering if anyone on here has had any experience.
  2. Feb 10, 2021 at 9:38 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    If I were you I would steer far away from the pro comp long travel kit. Its made from cast, not welded or boxed like other kits and would probably fall apart if you plan to actually off road. I would look into Total Chaos or any kit thats actually proven
    joonbug, GodlessPro and Sunnier like this.
  3. Feb 10, 2021 at 9:54 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, check Total Chaos; Camburg. The problem with getting a deal on long-travel is, anything substantial enough to support the weight of our trucks doing long-travel activities, is gonna cost.
    TG705 likes this.
  4. Feb 19, 2021 at 7:00 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    J&ATundra, vipgs3, Pekas99 and 6 others like this.
  5. Feb 19, 2021 at 7:01 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    If you want the LT wide stance look and some casual trail run. ProComp ain’t too bad.
  6. Mar 8, 2021 at 7:20 PM
    dylanschmarr
    dylanschmarr New Member
    dylan
    2013 White creamax
    6 inch procomp lift fox suspension 35x12.5 toyo open country a/t
    How did you get the seqouia headlights to work on your tundra. I wanted to do the same but I wasn’t sure about fitmant
    sillydadztrksR4momz likes this.
  7. Mar 8, 2021 at 7:25 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  8. Jun 23, 2023 at 7:42 AM
    Pekas99
    Pekas99 New Member
    Edgar
    2010 tundra single cab
    Lift kit Wheels
    did u run aftermarket spindles or oem ones ?
