Valuguard undercoating any good?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mustang67ford, Jun 19, 2023.
  1. Jun 19, 2023 at 2:18 AM
    Mustang67ford
    Mustang67ford [OP] New Member
    Has anybody had this applied by line-x? Didn't come up with much when doing a search on it.
  2. Jun 21, 2023 at 2:11 PM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    If I recall I think I read somewhere that Valuegard is a rubberized coating, much like Zeibart. If that is the case STAY AWAY! I bought a Rock Warrior years ago that the previous owner had Zeibarted every year for the first 5. The stuff held moisture under the coating and was rotting out the frame as bad as no coating, if not worse. I highly recommend WoolWax. It is lanolin based, is a little thicker than fluid film, comes in black and only needs reapplied every 2-3 years here in Ohio…according to my installer. When I had my 4Runner done 2 years ago it was $180. Still looks great!
    2mchfun likes this.
  3. Jun 21, 2023 at 2:29 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Haven’t personally used it or heard of it. I'm seeing conflicting reports on if valugard is rubberized hybrid or asphalt based. Maybe they make more than one type of product? I wouldn't do any kind of coating that isn’t a hydrophobic with wax or oil.
    I've heard good things about woolwax.
    I had fluid film applied by a local 4x4 axle building company, the last two years late fall. I try to avoid underbody washes so it doesn’t get sprayed off and touch up any area I work on with more fluid film after I’m done. The person that applied it stated if you avoid washing it off it can last 4-5 years but recommended touch ups every 2. I plan to continue touch ups every year in the fall on my own, but I have a friend with a lift so its easy/quick.
    WILLINH likes this.
  4. Jun 21, 2023 at 9:23 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
