2011-2018 Additional Transmission Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Dec 22, 2020.
  1. Sep 9, 2021 at 7:50 AM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Ordered... thanks for the update and link.
  2. Sep 11, 2021 at 1:34 PM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    Probably a dumb question, but does the addition of a transmission cooler effect how transmission fluid changes are performed in the future?
  3. Sep 16, 2021 at 1:48 PM
    ATHiker
    ATHiker New Member
    Tom
    Given the lack of a reply, I guess it was not such a dumb question after all.
    Mike59 likes this.
  4. Sep 17, 2021 at 3:50 AM
    Bammer
    Monroe, CT
    Cooler adds more fluid = good! Drain and fill is what needs doing, so no the procedure is the same, unless you are looking to do the drain and fill enough times to change all the fluid. So it might take an extra one or two times.
  5. Sep 17, 2021 at 3:52 AM
    timsp8
    NY
    No, it goes inline with the current cooler. It only adds about 1/4 qt of fluid. No one changing the fluid under the truck would even notice.
  6. Sep 17, 2021 at 10:24 AM
    timsp8
    NY
    Shouldn't affect the radiator at all. It doesn’t block much airflow or put out much more heat in front of it that wasn’t already there. It just adds more cooling surface area for the transmission fluid.
  7. Sep 17, 2021 at 1:09 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Can this kit be made to work on a 2020?
  8. Sep 17, 2021 at 1:46 PM
    ATHiker
    ATHiker New Member
    Tom
    Thanks for the reply. So when you change the tranny fluid, you just drain and refill per the current procedure.
  9. Sep 17, 2021 at 3:27 PM
    timsp8
    NY
    There is a different kit for the 19+ trucks. You’ll need the thermostat and lines. There’s another thread about it and it’s on his website too.
  10. Sep 17, 2021 at 3:58 PM
    pursuit2550
    Never mind. Brain fart. I forgot about the lines that don't run to the from of the truck.
  11. Sep 17, 2021 at 4:12 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    That radiator is overly secured to the mounting bracket, 12 screws lol. Meanwhile, I can only count 3 screws securing the mounting bracket to the vehicle.
  12. Sep 18, 2021 at 8:00 AM
    Genuine Cooling Systems [OP] New Member Vendor
    No change in the procedure to change your ATF.
    ATHiker[QUOTED] likes this.
  13. Sep 18, 2021 at 8:01 AM
    The bracket is extremely secure with the 3 bolts securing it.
  14. Sep 18, 2021 at 8:02 AM
    I don't. I build the brackets in CAD and send the files to a shop for CNC and powder coat.
  15. Oct 4, 2021 at 6:48 PM
    ATHiker
    ATHiker New Member
    Tom
    Have you installed the cooler and if so, do you have any comments?
  16. Oct 4, 2021 at 7:05 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Just installed additional cooler on my 2017.
    Nice kit easy install.
    I did some modifications because of my winch controller box placement.
    So I relocated cooler on driver side.
    Just drilled one extra hole on the bottom and got longer hoses.
  17. Oct 13, 2021 at 10:03 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    I have not installed yet. Wrapped up renovating a house to get on the market so the cooler is on the back burner for a winter project. I will say that the packaged kit looks top notch. It will be a simple install.
  18. May 11, 2023 at 6:46 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Can we get these going again?? Sorry for the old thread revival
  19. May 11, 2023 at 6:50 AM
    Js18tundra
    thats the full kit for the 19-21 tundras. I don’t need the full kit, I need the kit for the 18’ tundras in this thread.
  20. May 11, 2023 at 9:17 AM
    #50
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I know its offtopic somewhat, forgive me, yet I am curious how the stock trans fluid cooling for 11-18s takes place if the A/C in On and Off, is the cooling affect/reduction in heat the same? Meaning does it matter if I have the a/c on or not, thanks.
  21. May 11, 2023 at 10:49 AM
    #51
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    No need for the AC to be on. The cooler is just integrated into the condenser. If anything, the cooler will work slightly better with teh AC off due to the condenser getting warm when the a/c is running, but that is negligible.
  22. Jun 20, 2023 at 6:41 PM
    #52
    Js18tundra
  23. Jun 20, 2023 at 6:53 PM
    #53
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
