General Supercharger Thread
  1. Jun 20, 2023 at 2:45 PM
    #9091
    Saltyhero13
    Saltyhero13 Throbbing Member
    Any recent interactions with the killerchiller vendor? Has the situation improved?
    What was the name of the alternative product again?
    Winks4x4Toy likes this.
  2. Jun 20, 2023 at 2:45 PM
    #9092
    Saltyhero13
    Probably the most important finding of note.
  3. Jun 20, 2023 at 2:55 PM
    #9093
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Don't go with KillerChiller, I purchased a kit from them in August, never received it...go with these guys, they actually respond to emails...
    https://fiinterchillers.com/
  4. Jun 20, 2023 at 3:02 PM
    #9094
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Yes exactly! Not a minor issue at all.
  5. Jun 20, 2023 at 3:05 PM
    #9095
    snivilous
    SW UT
    300k+ Supercharged 2008
    Maybe that should be added to the first post just to impress on people that Stage 1, while it works, does not make for a happy truck.
  6. Jun 20, 2023 at 3:14 PM
    #9096
    ZPhilip
    Philip
    West Chester, PA
    Man those are some scary numbers. I forgot how much timing was being pulled.
    And I recently spoke with Chris @ Harrop who still is keeping his Sequoia at Stage 1 untuned because it “runs so well.”
  7. Jun 20, 2023 at 3:18 PM
    #9097
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Well yeah, lean runs better, until it doesn't.
  8. Jun 20, 2023 at 3:19 PM
    #9098
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The scariest part of all to me with stage 1 was the lack of part throttle enrichment. High load+boost+lean AFRs in those scenarios=bad. I wouldn’t be towing with stage 1 that’s for sure.
  9. Jun 20, 2023 at 3:19 PM
    #9099
    snivilous
    SW UT
    Yea no kidding, nearly 5deg pulled and all over the place, and is essentially leaning out over 5000rpm at full throttle.
    But as always, I don't claim to be a tuner, and every place I've seen seems to do tuning differently and prioritize things differently. Viktor is the only one I've seen that seems to actually address knock retard. Maybe it's not that big of an issue considering other tuners ignore it completely, but that doesn't seem right, otherwise why not just run gnarly timing everywhere and let the truck retard everything? But to each their own, and I'm not an expert. (And maybe some tuners do address it, I haven't seen how everyone does it)
    mZiggy, Wynnded and Saltyhero13 like this.
  10. Jun 20, 2023 at 3:23 PM
    #9100
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Final items arrived today. Should be good to go to install this weekend if the old lady leaves me alone lol. @snivilous adapter plate fits perfect! Had to mock up the intake pipe just to see.
  11. Jun 20, 2023 at 3:23 PM
    #9101
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    im thankful my sh1t held together
    I tuned it as soon as it was avail.
    Saltyhero13[QUOTED] likes this.
  12. Jun 20, 2023 at 3:24 PM
    #9102
    snivilous
    SW UT
    That is absolutely gorgeous! Glad everything went together smoothly!
  13. Jun 20, 2023 at 3:28 PM
    #9103
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That looks really nice!
    @snivilous I'll get those dimensions to you soon, finally getting some time to work on the truck this evening.
  14. Jun 20, 2023 at 3:32 PM
    #9104
    snivilous
    SW UT
    Awesome! Rey and I have been talking about the LS throttle body, we were suspicious that the Whipple bolt pattern was a LS pattern which it doesn't seem to be (or doesn't match any of the LS throttle bodies I have laying around). So the next thing will be figuring that out, if I could get the adapter to fit both the Whipple and Harrop that would be cool, though would probably lack in the aesthetics department then... We'll figure that bridge out when we get there.
  15. Jun 20, 2023 at 3:33 PM
    #9105
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Interior transition is smooth!!
  16. Jun 20, 2023 at 3:51 PM
    #9106
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    il_1080xN.3571092674_50s8.jpg Sexy.[​IMG]
  17. Jun 20, 2023 at 5:35 PM
    #9107
    ZPhilip
    Philip
    West Chester, PA
    I don’t even want to know where you found that pic.
  18. Jun 20, 2023 at 5:39 PM
    #9108
    ZPhilip
    Philip
    West Chester, PA
    Gotta admit the gold is growing on me. My all black looks so boring.
  19. Jun 20, 2023 at 5:42 PM
    #9109
    ZPhilip
    Philip
    West Chester, PA
    Yea you aren’t kidding. My PE kicks in at 30 percent now and I can still build 2 psi before PE under low rpm higher loads.
  20. Jun 20, 2023 at 6:38 PM
    #9110
    Saltyhero13
    I’m scaroused…
    …I’m going to need a link.
  21. Jun 20, 2023 at 7:05 PM
    #9111
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The Harrop mounting hole configuration is for the stock Tundra throttle body in two different options, so you can rotate the throttle body 90 degrees. The mouth is 84mm, and I'm planning to use the 90mm GM throttle body for now.
    The Harrop TB mount is already hideous, there is ~7mm of meat around the most narrow part of the mouth of the Harrop, that's the only measurement I noted, as far as the shape goes...see below.
  22. Jun 20, 2023 at 8:54 PM
    #9112
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    man....why you gotta post this...now i really want one lol
  23. Jun 21, 2023 at 6:23 AM
    #9113
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's how all this works...
  24. Jun 21, 2023 at 6:24 AM
    #9114
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Diderot effect.
    look it up.
    50Shades[QUOTED] and HulkSmurf14 like this.
  25. Jun 21, 2023 at 7:28 AM
    #9115
    ssmokedz
    Shelton CT
    Damn that looks nice!!! Snivs plate looks fantastic. Can't wait to see the results.
  26. Jun 21, 2023 at 8:26 AM
    #9116
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Now I "need" an olde French Encyclopédie.
    lol
    nobodyintexas[QUOTED] likes this.
  27. Jun 21, 2023 at 9:20 AM
    #9117
    e30cabrio
  28. Jun 21, 2023 at 9:29 AM
    #9118
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  29. Jun 21, 2023 at 9:51 AM
    #9119
    e30cabrio
    I neither need nor will I be getting either.
    lol
    M3Tundra-JK likes this.
  30. Jun 21, 2023 at 10:31 AM
    #9120
    snivilous
    SW UT
    90mm GM throttle body to Harrop adapter for @armyoffoo. If any other Harrop guys want one let me know, I will be getting a quote later today.
