Engine Oil for 1st Gen V-8
Discussion in '1st Gen Tundras (2000-2006)' started by tda003, Jun 19, 2023.
  1. Jun 19, 2023 at 3:27 PM
    tda003
    tda003 [OP] New Member
    Tom
    St. Simons Island, GA 31522
    2005 Tundra Access Cab, SR-5. 2-wheel drive. V-8.
    None (so far)
    What, if any, is the advantage of regular vs synthetic blend vs full synthetic oil in my
    '05 V-8 Tundra. I change every 5000 miles. Also is there a significant advantage of one brand vs another?
  2. Jun 19, 2023 at 3:33 PM
    Synthetic makes a significant difference in moisture caused sludge accumulation between oil changes when you regularly take short trips from home.
    FlyingWolfe likes this.
  3. Jun 19, 2023 at 3:36 PM
    Aerindel
    Aerindel New Member
    Montana
    The simple answer is...not really. The differences between regular or synthetic and one brand to another is trivial.
    The second simplest answer is....why not use synthetic? Its cheap, and widely available. More so than dino oil these days which is getting harder to find. There is no reason not to use. At worst, it's no worse, and at best, slightly better protection and gas mileage.
    Costco store brand is pretty popular and comes in handy 5 quart box.
    Stankfinger76 likes this.
  4. Jun 19, 2023 at 3:59 PM
    tda003
    Tom
    None (so far)
    Thanks.
  5. Jun 19, 2023 at 4:01 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Hubs has been using Mobil1 full syn and has over 300k trouble free miles, pulled his valve covers for recent maintenance and everything was showroom new so I go by that data. :notsure:
    Elevatorguy likes this.
  6. Jun 20, 2023 at 5:00 AM
    shifty` Bohannon Bohannon Bohannon Bohannon
    Less important than the oil you use is the schedule you choose, especially true for short-trip drivers. Short-trip driving is brutal on your engine. Talking to you folks who drive 5-10 miles or less, park for a while, then rinse/repeat. Even worse if that's all stop-and-go miles. in that case, you need to be changing your oil based on months vs. miles, 12mos/3k miles max and I'd recommend full syn. You'll notice more varnish and potential sludge from moisture that never has time to burn off, and it'll be worse with dino oil than full syn.
    Sure, there are some corner cases on the mileage thing. Maybe you only drive the truck every weekend on a 50-250 mile round trip or something, running the boat to your favorite hole to launch and back home again, hauling gear and family to the cabin for the weekend, whatever it may be. I can see using a 5k mile schedule then. Or if you're purely highway mileage, using as a commuter 90% of your mileage and using full syn, 10k miles.
    Folks need to get it out of their head that mileage is key. The last owner of my truck made a short jaunt daily, had oil changed based on mileage at a local Jiffy lube. What I found under the valve covers when doing the gaskets was gnarly.
    Schcoman likes this.
  7. Jun 20, 2023 at 5:44 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I’ve used Mobil one exclusively for 20 years. Most of my yotas run the 10k intervals, my truck doesn’t see that kinda mileage so I change it once a year. I change our tlx type s at 5k, it gets driven hard at times.
  8. Jun 20, 2023 at 6:07 AM
    CTundraForMe
    CTundraForMe New Member
    Hi, if you look around, there are numerous threads about this.
    Synthetic is better.
    One brand vs another brand is debatable, usually with no conclusion!
    I'm an Amsoil fan personally. It's a $50k truck, why go cheap on oil?
  9. Jun 20, 2023 at 8:05 AM
    Elevatorguy
    James
    When was a 1st gen 50k?
    Aerindel and Casper421 like this.
  10. Jun 20, 2023 at 8:06 AM
    Casper421
    In the woods
    06 DC
    1st gens weren’t $50k brand new, barely $35.
  11. Jun 20, 2023 at 8:08 AM
    Casper421
    In the woods
    06 DC
    Mobil1 for me. In the engine, t-case and diffs.
    shifty` likes this.
  12. Jun 20, 2023 at 8:27 AM
    CTundraForMe
    Re the 50k, I was talking about my truck. 1st gen + inflation would be the same or higher?
  13. Jun 20, 2023 at 8:33 AM
    A little lower. I paid $27.5k (invoice) on an SR5 with decent options.
    I’m looking at close to $60k for a new SR5 that’s similar
  14. Jun 20, 2023 at 8:36 AM
    18" TRD Off Road Wheels
    FirstGenVol and PKFan like this.
  15. Jun 20, 2023 at 8:39 AM
  16. Jun 20, 2023 at 8:40 AM
    @Bob
  17. Jun 20, 2023 at 8:42 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    Your uncle.
  18. Jun 20, 2023 at 8:45 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    PKFan[QUOTED] likes this.
  19. Jun 20, 2023 at 8:49 AM
    I shouldn’t have asked! :rofl:
    GODZILLA likes this.
  20. Jul 3, 2023 at 6:50 AM
    Anvilhead
    Anvilhead New Member
    '03 Tundra 2WD Access Cab V8
    None
    When I bought it used from Hertz Sales in 2011. Currently at 232k.
  21. Jul 3, 2023 at 6:58 AM
    You bought a 1st gen Tundra, from a rental car place, 12 years ago for $50k? What the :censored::goingcrazy:
  22. Jul 3, 2023 at 7:00 AM
    Anvilhead
    None
    Oh dude, I thought <50k miles!! .
    I paid $10k when it had 31k miles. Best $10k I ever spent.
