Tundra won't start
Discussion in '2.5 Gen Tundras (2014-2021)' started by OregonBeaver, Jun 11, 2023.
  1. Jun 11, 2023 at 12:22 AM
    OregonBeaver
    OregonBeaver [OP] New Member
    Kyle
    2019 tundra
    Picked up a new to me 19 tundra 5.7l about 2 months ago. Had about 2 weeks and it wouldn't start. (Dead battery) took it to schwabs and got a new one. Today the same issue, schwabs replaced the battery. So now I'm thinking alternator. Dug out the meter and with it running it reads 13.5volts. Isn't this within reason or should it be higher? I'm stumped
  2. Jun 11, 2023 at 6:54 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    2mchfun likes this.
  3. Jun 11, 2023 at 7:02 AM
    2mchfun
    Check your battery voltage
  4. Jun 11, 2023 at 7:04 AM
    2mchfun
    Might have bad main fuse, bad ground, or bad cables all around. The whole system has got to be good, a good battery and good alternator is only part of the system. Good luck!
  5. Jun 11, 2023 at 7:05 AM
    2mchfun
    Welcome to the forum from OKC!
  6. Jun 11, 2023 at 7:16 AM
    1UP
    1UP Truck Gang
    2mchfun likes this.
  7. Jun 11, 2023 at 1:32 PM
    OregonBeaver
    Kyle
    2019 tundra
    Not super mechanically inclined but the fuse looked fine, terminals in good shape. Looks like it has a parasitic draw. Pulled the negative cable and tested it with the meter. Was hovering at 1amp to 90mil amps. Is that the culprit for dead batterys? The previous owner had installed after market stereo,Amp, subs. Running board lights, 6 different light bars.. viper alarm. Going to assume one of these is the issue.
    ATV25 likes this.
  8. Jun 11, 2023 at 1:57 PM
    1UP
    1UP Truck Gang
    Yeah, I'd start by disconnecting one at a time and measuring to isolate the culprit.
  9. Jun 16, 2023 at 11:02 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
  10. Jun 20, 2023 at 2:49 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    That Viper alarm is probably the culprit. Does it have a remote start?
  11. Jun 20, 2023 at 2:57 AM
    OregonBeaver
    Kyle
    2019 tundra
    It does yeah
  12. Jun 20, 2023 at 3:01 AM
    Retired...finally
    Are there any additional wires added to your battery terminals? If the main power to the amp or subs was connected directly to the positive terminal, my guess is your problem lies there. You mentioned 90 ma to 1 amp? 90 isn't too bad but 1,000ma is a real problem.
  13. Jun 20, 2023 at 3:11 AM
    OregonBeaver
    Kyle
    2019 tundra
    It was only about 90 to 100ma. It took roughly a month to kill the last battery. There's several other wires hooked up to the positive terminal. I went thru and disconnected everything 'extra' that was on the battery. Still had a draw...the only way I got it to stop. Theres a heavier gage wire hooked up to the battery that goes to the fuse box I believe to power it. So I pulled fuses for radio, alternator etc..no luck. It's a bit beyond my capabilities of figuring out.
  14. Jun 20, 2023 at 4:42 AM
    Retired...finally
    A month of the truck not running? That might be a bit long with all the normal parasitic drain these vehicles normally have.
  15. Jun 20, 2023 at 4:52 AM
    OregonBeaver
    Kyle
    2019 tundra
    I had bought a battery when I first bought the truck. Went to start one morning and it was dead. Took to our tire store and got another one. Assumed that fixed the issue. Last week..same thing..dead truck and battery. About month since I had purchased battery before it killed it. I thought at first it'd be the alternator. At this point I wish it was..lol trying to narrow down a parasitic draw is a pain in the butt
