Best model for towing
Discussion in 'Towing & Hauling' started by Linebacker61, Jun 20, 2023.
  1. Jun 20, 2023 at 2:59 AM
    Linebacker61
    Linebacker61 [OP] New Member
    Joe
    Haven’t bought my T yet. Seems the biggest challenge is the rear sag when towing. Would the Sport package be the best considering the stiffer suspension (2,5 Gen). ?
  2. Jun 20, 2023 at 3:48 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Anything with a bulldog on the hood is going to be adequate for any towing scenario you could possibly envision.
    May I recommend the 15 liter powersource to sir?
  3. Jun 20, 2023 at 3:49 AM
    A double cab would most likely get you the best payload (except a reg cab).
    Having a properly set up LDH works wonders in the rear sag department.
    JLS in WA likes this.
  4. Jun 20, 2023 at 5:12 AM
    18" TRD Off Road Wheels
    Depends on what you are towing. A SxS on a utility trailer will be fine for any trim, a small boat is easy enough, but if you are looking at 24'+ travel trailers with slide outs and all the amenities of home then you need to go buy an HD truck because that's going to be a way better suited tow rig than any half ton.
    Assuming you are staying within the actual limits of a 1/2 ton; the best thing you can do for sag is use a weight distributing hitch that has been properly set up. That, or get a Trailer Toad or equivalent.
    2mchfun likes this.
  5. Jun 20, 2023 at 6:32 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The TRD Pro would be the worst trim for towing as it has softer springs and no rake. Other than that, all the other trims should be pretty much the same.
    Pbed85, JDR76 and RostamD like this.
  6. Jun 20, 2023 at 7:24 AM
    JRS
    JRS New Member
    2012 DCLB
    I tow lighter loads, boat and utility/enclosed trailers, no RVs, but the long bed is nice.
  7. Jun 21, 2023 at 7:28 AM
    7Toys4Me
    7Toys4Me New Member
    2023 Tundra CrewMax 1794 HV 4X4
    doesn’t the Pro have adjustable shocks standard?
  8. Jun 21, 2023 at 9:05 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    That's good info. I recognize him from an article I've shared on the forum where he says that in certain cases, a 1/2 ton might handle a travel trailer better than some 3/4 tons due to having IFS, nearly the same size brakes, and a lower center of gravity.
    I'm guessing it's because Andy commits the grave internet sin of stating that it's ok to be a bit over GVWR when the trailer weight is within what the manufacturer says the truck can handle and neither axle is overloaded.
    Mattedfred[QUOTED] likes this.
  9. Jun 21, 2023 at 9:46 AM
    Terndrerrr
    Music City
    6UR-FE
    Very cool. My general rule of thumb is that if I'm within axle limits, then I can't be above GVWR by enough to have any problems at all. Towing is also something I do very rarely. If I bought a truck for the purpose of towing, I'd probably have a different truck.
  10. Jun 22, 2023 at 6:48 AM
    Anecdotal evidence and confirmation bias make up 87% of the postings on the internet. You’ve come to the wrong place it seems.
  11. Jun 22, 2023 at 7:04 AM
    2mchfun
    What are you planning on towing? Where are you planning on towing? High elevation and steep grades make a difference if you are pulling on the big and heavy end of the spectrum. Be mindful of auxiliary transmission coolers, suspension modifications, tire load ratings, differential gear modifications, and supercharged engines. Lots of options.
  12. Jun 22, 2023 at 7:43 AM
    Retired...finally
    I dunno about that. My Butt-o-Meter sez I get 10.245% increase in raw rear wheel horse power when I wash and wax my Tundra.:rolleyes:
    sandiegosteve, 2mchfun and KNABORES like this.
