Bending Radiator Hardlines
Discussion in '2.5 Gen Tundras (2014-2021)' started by Underdogg, Jun 18, 2023.
  1. Jun 18, 2023 at 3:23 PM
    Underdogg
    Underdogg [OP] New Member
    07 Crewmax 5.7L
    I am trying to fit a Victory 4x4 strike bumper onto the tundra. In order to make room for the winch, they give you offset brackets for the tube radiator and the video instruction they have for the install directs me to bend the hardlines so the radiator sits flush with the rad frame.
    I got the brackets installed which kind of pushes the lines back but it can't bend it really and I am afraid to use too much force. Should I just send it and push the hell out of it or is there a better way to do this? I will attach pics.
    Side note, I'm annoyed with Victory. The bumper isn't fitting right to begin with and this thing was pricey as hell. Having to bend these lines to make room for the winch was something I wasn't expecting either.
    BlueRibbon4x4 likes this.
  2. Jun 18, 2023 at 4:48 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Underdogg[OP] likes this.
  3. Jun 18, 2023 at 4:55 PM
    1UP
    1UP Truck Gang
    I was complementing @BlueRibbon4x4 on his oem looking fab earlier. Maybe he ran into the same issue?
  4. Jun 18, 2023 at 7:22 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I have the Victory Blitz bumper but had the same issues with the hard lines. I did have to bend them back but just be seriously careful about kinking the line (I’m sure you’re already doing so). Also, pay attention to the driver side bumper mount on the frame that it doesn’t rub the hard line at all, mine did, but I caught it in time.
    Underdogg[QUOTED][OP] and 1UP like this.
  5. Jun 18, 2023 at 10:49 PM
    Underdogg
    07 Crewmax 5.7L
    Good advice, will do
    BlueRibbon4x4[QUOTED] likes this.
  6. Jun 18, 2023 at 10:49 PM
    Underdogg
    07 Crewmax 5.7L
  7. Jun 19, 2023 at 8:33 AM
    1UP
    1UP Truck Gang
  8. Jun 19, 2023 at 11:38 AM
    2mchfun
    There are small plier like tubing benders available at tool stores and online. Might help if you can get access to the area you need to modify. As said above, you don't want to kink it.
