Sequoia headlights
Discussion in 'Lighting' started by Dgravee, May 4, 2023.
  1. May 4, 2023 at 7:35 PM
    Dgravee
    Dgravee [OP] New Member
    2010 tundra sr5 crewmax
    So I just swapped to the sequoia headlights, I think it looks pretty good but I keep looking at the Morimoto website and thinking I want those headlights more now… I ordered the harness through a member on this site which works great and have painted the fender extensions with paint matched to my factory IF9 paint and sprayed them with spray max 2k clear. They turned out great in my opinion. If anyone is interested in these let me know! And let me know what you think of these vs Morimotos.
    Schmidt_l and V3N0M like this.
  2. May 7, 2023 at 11:16 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I think that the morimoto and sequoia headlights are the 2 best options for upgrading lighting on the gen 2. I'm still on the fence of which route I'm going but if it were my rig I'd leave it alone. You have the poor lighting issue resolved and it looks badass.
    Trusty Rusty likes this.
  3. May 16, 2023 at 9:38 AM
    Schmidt_l
    Schmidt_l New Member
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    Looks good! im planning in doing the same with OEM headlights, where do you got the harness from?
  4. Jun 19, 2023 at 5:52 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    @xrunnerdude67 he makes them
  5. Jun 19, 2023 at 6:02 AM
    Schmidt_l
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    Did mine myself, after putting 2 types of harness together, couples connectors, some burnt fuses and a lot of hours figuring out got it done!
    thx though
    BrandonL812 likes this.
  6. Jun 19, 2023 at 6:04 AM
    BrandonL812
    Brandon
    Did you take pictures along the way?
    Schmidt_l likes this.
  7. Jun 19, 2023 at 6:07 AM
    Schmidt_l
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    yep
    got some pics during the frustration times when i had the diagram of the wired going to the 8pin and i did it upside down
  8. Jun 19, 2023 at 6:09 AM
    BrandonL812
    Brandon
    Sweet. Maybe you can post a diy?
  9. Jun 19, 2023 at 6:23 AM
    Schmidt_l
    Leidir (Lay-Jeer)
    2008 Tundra Sr5 DC
    Grille??
    If you’re kinda of electrician inclined
    you can figure it out
    the main part is the diagram and getting some sort of harness with a relay to start and then male connectors for the turn light, lower and high beam, some sort of de-pin and pin kit to wire it to the OEM 8pin headlight connector
  10. Jun 19, 2023 at 6:28 AM
    BrandonL812
    Brandon
    Doable. Thanks
  11. Jun 19, 2023 at 6:53 AM
    Absolutely hands down best mod for 2nd gens appearance. Modernizes it and definitely improves lighting output! I like the OEM Seqouia conversions a little better than the Morimotos, but both are a dramatic improvement. Looks awesome guys!!
