Musty smell from A/C
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rsolano87, Jun 18, 2023.
  1. Jun 18, 2023 at 9:35 PM
    Rsolano87
    Rsolano87 [OP] New Member
    Randolph
    2024 tundra trd off road
    Westcott design pre load collar lift
    Hey Y’all
    My 2021 has this musty smell coming from vents after A/C is turned off. I’ve checked the cabin air filter, it’s clean as a nuns sheets. I’m thinking moisture stuck in there and mold growing. Any ideas for best way to check ?
  2. Jun 18, 2023 at 10:22 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Get them air vent cleaner
    Rsolano87[OP] likes this.
  3. Jun 18, 2023 at 10:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Residual moisture from the ac causing odor problems is fairly common. Usually it’s kind of a dirty sock/wet locker kind of smell.
    You can treat the duct work by spraying a disinfectant like Lysol into the intake with the fan set to recirculate.
    Also you can reduce the moisture by running the fan on high with the ac turned off for 5 or 10 minutes before turning off the engine. Easy to do if you remember to do that before you get to your destination
    Joe333x, Rsolano87[OP] and GODZILLA like this.
  4. Jun 18, 2023 at 11:30 PM
    art64
    art64 New Member
    I replaced the stock cabin air filter with charcoal infused one and never had that problem again. I just don't remember the brand as this was probably 5 years ago. The airflow was greatly improved over the one that I replaced, although it didn't look that dirty. I don't use the truck that much nowadays, I'll replace it before peak of summer hits.
    gosolo and Rsolano87[OP] like this.
  5. Jun 19, 2023 at 4:16 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
  6. Jun 19, 2023 at 4:21 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Ozone machine may work too if the vent cleaner doesnt
    TundraDan723 and Rsolano87[OP] like this.
  7. Jun 19, 2023 at 4:53 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    If the smell is coming from the condenser, I doubt an ozone machine would help much. Worth a try though.
    I've been battling this with my wife's 2016 Accord. Somewhere on this page someone posted a link to a product that will clear out the condenser I believe.
  8. Jun 19, 2023 at 5:00 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  9. Jun 19, 2023 at 7:17 AM
    Rsolano87
    Randolph
    Thank you for all the suggestions. I’m gonna go down the list and see which does the trick. Appreciate y’all.
    ToyoMafia, Musicmasterd12 and gosolo like this.
  10. Jun 19, 2023 at 7:18 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Alternatively, if you tie a dead skunk to your driveshaft, you will not notice any odors from the ac vents for a very long time
  11. Jun 19, 2023 at 7:33 AM
    Rsolano87
    Randolph
  12. Jun 19, 2023 at 7:43 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  13. Jun 19, 2023 at 4:16 PM
    WiscoWalleye
    WiscoWalleye New Member
    I did mine with the Toyota Kit. It does a great job. However the instructions are different for our trucks since the drain hole is above the transmission and not easy to get to. Plus it’s not a hose. So you just have to drop the blower motor and run the hose down the vent. Here is a super straight forward video of a guy doing it on a Land Cruiser it’s exactly the same.
    https://youtu.be/fPOfecY7MF0
  14. Jun 19, 2023 at 4:37 PM
    Rsolano87
    Randolph
    Solid. Thank you!
    ToyoMafia likes this.
  15. Jun 19, 2023 at 4:47 PM
    WiscoWalleye
    No problem! One thing I did differently is tape the hose for the foam kit to the end of my bore scope so I could direct it on the condenser behind the dash. Totally unnecessary since the foam expands to fill the whole cavity but it was nice piece of mind and helped direct the flimsy hose.
  16. Jun 22, 2023 at 2:46 PM
    art64
    art64 New Member
    This is the filter that I bought: Breath Easy Cabin Filter w/ Activated Carbon. BE-285
    Available on Amazon for $10.97. I had purchased this twice before.
  17. Jun 22, 2023 at 3:18 PM
    Rsolano87
    Randolph
    Ended up just taking truck back to Toyota dealership in San Diego for a few issues. They did the Ac refresh for free along with some other stuff requested. Pretty solid customer service
    MadMaxCanon and Musicmasterd12 like this.
  18. Jun 24, 2023 at 12:32 PM
    WiscoWalleye
    Sweet! Did it solve the issue.
  19. Jun 24, 2023 at 2:17 PM
    Rsolano87
    Randolph
    Sure did. Solid suggestion
    WiscoWalleye[QUOTED] likes this.
  20. Dec 12, 2023 at 12:39 PM
    turk
    turk New Member
    greg
    millersville pa
    2011 platinum
    i tried all these methods and also had toyota run ther machine on the system a waste of money. the drain hose ahad no water to speak of in it also. i belive the customer relations person said it probably in the dash hoses. i know this guy for 30 yrs. so i don't think he is blowing smoke. help.
