Light won’t come on
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Jun 18, 2023.
  1. Jun 18, 2023 at 12:46 PM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    help!!
    I can’t get this to turn off.
  2. Jun 18, 2023 at 1:15 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Is it just one side of the light?
    Just to get it off you can pull the dome fuse or the bulb..
    Maybe the on switch is bad in the light.:confused:
    1Tundra5[OP] likes this.
  3. Jun 18, 2023 at 1:34 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Seriously, I'm not trying to be an ass, but did you push the button on the back side of the dome?? Some folks don't know there are 2 buttons back there cuz they've never been in the back seat...
    If you have, my apologies; and then try what those other dudes said. Except the hammer thing, don't do that; it'll make a mess!!
  4. Jun 18, 2023 at 1:43 PM
    1Tundra5
    Junior
    2015 White SR5
    Yes, it’s the one on the passenger side.
  5. Jun 18, 2023 at 1:50 PM
    1Tundra5
    Junior
    2015 White SR5
    Yeah, first thing I did, hoping it was just that.
  6. Jun 18, 2023 at 1:51 PM
    Tripleconpanna
    So what happened when you pulled the fuse and then put it back in??
  7. Jun 18, 2023 at 1:52 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Push the lock button on your key twice
  8. Jun 18, 2023 at 6:50 PM
    1Tundra5
    Junior
    2015 White SR5
    Didn’t help unfortunately
  9. Jun 18, 2023 at 7:11 PM
    1Tundra5
    Junior
    2015 White SR5
    Which is the dome fuse? I was trying to take the extremely hot bulb out, and it pushed it into the headliner area when I got it free.
    happy Father’s Day :annoyed:
    I’ll just continue tomorrow
  10. Jun 18, 2023 at 9:05 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Dome fuse is under the hood in the main fuse box for 2007-2018... 2019 they moved it to the interior box by the steering column which does make more sense but what can you do.
    It is #23 on this diagram (https://imgvehicle.com/toyota/tundra-ii/fuse-box)
  11. Jun 19, 2023 at 5:17 AM
    1Tundra5
    Junior
    2015 White SR5
    oh man, thanks a bunch.
  12. Jun 19, 2023 at 7:45 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I'm confused.
    The title reads the light won't come on, the OP reads the light won't go off.
    Which one is it?
    Did you recently replace the bulbs?
    I'll pull it down and check the bulb connections as well as the circuit board.
    Some of those board connections are really close together, make sure they aren't shorting out.
  13. Jun 19, 2023 at 12:21 PM
    1Tundra5
    Junior
    2015 White SR5
    Sorry, I tried to correct the tittle yesterday, but wasn’t able to. Should’ve read off, not on.
    1lowlife[QUOTED] likes this.
  14. Jun 19, 2023 at 12:23 PM
    1Tundra5
    Junior
    2015 White SR5
    didn’t do anything.
    I pulled the bulb from the side that’s working fine, and as soon as I put it in the side that’s acting up, it came back up.
    So something is causing it to stay on no matter what
  15. Jun 21, 2023 at 11:42 AM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    2015 White Tundra Crewmax SR5
    Did you get this fixed yet? Its been a few days since the last post. If not, Id remove the lens and take out the light bulb first. Then, remove the whole light from the ceiling and double check the wiring and contact points. The contact points may have corrosion. Use a metal scrubber or scotch brite sponge and scrub them before putting the light bulb back in. If those are fine, then id look into buying new light bulbs. Since it’s also just one side, i would check the switch for that side. If it doesnt click when you press it, then something must be preventing it from doing so.
  16. Jun 21, 2023 at 11:58 AM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    Check behind this n make sure it actually clicks when being pressed.IMG_3086.jpg
  17. Jun 21, 2023 at 12:46 PM
    1Tundra5
    Junior
    2015 White SR5
    I haven’t fixed it.
    Not sure what else to try, so for now the bulb is out.
    Thanks for the advise, I’ll try that this weekend.
    Hope it works
  18. Jun 21, 2023 at 12:49 PM
    1Tundra5
    Junior
    2015 White SR5
  19. Jun 21, 2023 at 12:53 PM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    I will test mine and let you know shortly
  20. Jun 21, 2023 at 1:14 PM
    2mchfun
    You can always resort to the wiring diagrams in the garage heading and electrical subheading here on the site. Seems to me like you have a faulty switch or contacts.
  21. Jun 21, 2023 at 1:20 PM
    dofu
    dofu New Member
    Dave
    San Jose, CA
    @1Tundra5 Ok, i just tested mine and the switch by the steering wheel does not turn off the back dome light when its on. It doesnt act as a kill switch. I would say your best test would be if the button clicks when you press it on n off.
