Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Jun 14, 2023 at 10:38 AM
    #1201
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    He said they were warrantied, I'd assume they just rebuilt any messed up parts and didn't swap out the housing, so that's just rust from when Cruzer sent them in.
    I'm not aware of CV axles being balanced. Considering they're full of grease I think that'd be pretty futile too.
    rockmup, Cruzer[OP], des2mtn and 2 others like this.
  2. Jun 14, 2023 at 11:48 AM
    #1202
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Those came off my truck and I sent it back to RCV to replace the damaged components.
    Are they balanced like a driveshaft is balanced? I have no idea but probably wouldn’t be too concerned as the RPM is very low for its rotating mass.
    AstroDude[QUOTED] likes this.
  3. Jun 14, 2023 at 10:07 PM
    #1203
    NakdGpa
    NakdGpa New Member
    Dallas, TX
    2021 DC SR5 4x4 Cement
    4” lift, Method wheels, 295/70R18 Mickey Thompson’s, TRD F&R Sway Bars, Tinted...
    Thanks for giving a bike a little extra space! :bikewheelie:
    Pretty sure I passed you on 680 earlier this evening. Caught your plate at the last second, and took me a minute to realize where I knew it from.
    Mater, SAGE63, eccracer104 and 2 others like this.
  4. Jun 14, 2023 at 10:20 PM
    #1204
    Cruzer
    Cruz
    Sunnyvale, CA
    Past Fremont yeah?
    NakdGpa[QUOTED] and FrenchToasty like this.
  5. Jun 14, 2023 at 10:21 PM
    #1205
    Hopefully the magnet was still on
    Sunnier, Mater and Cruzer[QUOTED][OP] like this.
  6. Jun 14, 2023 at 10:23 PM
    #1206
    Cruzer
    Cruz
    Sunnyvale, CA
    Lol saving it for the next event ;)
  7. Jun 14, 2023 at 10:26 PM
    #1207
    I know a guy who can send more………
    I’m the guy
    but not THE guy, just a guy who has some
  8. Jun 14, 2023 at 10:39 PM
    #1208
    NakdGpa
    NakdGpa New Member
    Dallas, TX
    Yep, that’s the area.
  9. Jun 17, 2023 at 12:42 PM
    #1209
    Cruzer
    Cruz
    Sunnyvale, CA
    :monocle:
    Went to swap the driver side CV axle and saw this crack on the front LCA mount where my drop bracket is mounted to.
    @snivilous how would you repair and reinforce this? Butt weld the crack and maybe gusset it to the crossmember?
  10. Jun 17, 2023 at 12:47 PM
    #1210
    Definitely drill a hole at the end of the crack to keep it from spreading
    Mater, des2mtn, Sunnier and 1 other person like this.
  11. Jun 17, 2023 at 12:58 PM
    #1211
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    I've always put them in a ziplock and dropped them in the tire.
  12. Jun 17, 2023 at 1:11 PM
    #1212
    Cruzer
    Cruz
    Sunnyvale, CA
  13. Jun 17, 2023 at 1:23 PM
    #1213
  14. Jun 17, 2023 at 1:26 PM
    #1214
    Cruzer
    Cruz
    Sunnyvale, CA
    After further review it won’t but it gives me some ideas though.
  15. Jun 17, 2023 at 1:41 PM
    #1215
    Was that the same side your wheel said goodbye?
  16. Jun 17, 2023 at 1:58 PM
    #1216
    Cruzer
    Cruz
    Sunnyvale, CA
    I knew this question would come up :rofl: Nope it’s not the launcher.
    I have been hearing funny noises from this side so maybe this is why.
  17. Jun 17, 2023 at 2:12 PM
    #1217
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  18. Jun 17, 2023 at 2:13 PM
    #1218
    zeekevin
    zeekevin New Member
    that’s where I accessed my tank, I jammed a metal clothes hanger in there, never had an issue since.
    Cruzer[QUOTED][OP] likes this.
  19. Jun 17, 2023 at 3:47 PM
    #1219
    Cruzer
    Cruz
    Sunnyvale, CA
    Well that sucks.
  20. Jun 17, 2023 at 3:49 PM
    #1220
    Cruzer
    Cruz
    Sunnyvale, CA
    So I partially dropped the drop bracket, drilled a hole and trying to chamfer the crack.
    Does anyone else see a dolphin with a rhino horn and goatee?
  21. Jun 17, 2023 at 4:17 PM
    #1221
    snivilous
    SW UT
    I would just cut it open with an angle grinder, chamfering it would be nice but it you just slot the crack you'll get full penetration and might be easier than chamfering. Then plate over it with a diamond or something. And inspect the other spots. That's what I would do, but I'm not a welder :D
  22. Jun 17, 2023 at 4:36 PM
    #1222
    SAGE63
    San Diego County
    Yea
    Yeah I could agree with a dolphin
    rockmup and Cruzer[QUOTED][OP] like this.
  23. Jun 18, 2023 at 2:54 PM
    #1223
    rockmup
    rockmup New Member
    Todd
    FrenchToasty and Cruzer[OP] like this.
  24. Jun 18, 2023 at 2:59 PM
    #1224
    Cruzer
    Cruz
    Sunnyvale, CA
  25. Jun 18, 2023 at 4:06 PM
    #1225
    Casper421
    In the woods
    06 DC
    Fill it, grind smooth and plate both sides.
  26. Jun 18, 2023 at 6:55 PM
    #1226
    rockmup
    rockmup New Member
    Todd
    Little bit, lol
    I don't think I'd plate that, you'd have a hard time welding all four sides with a mig anyway. Unless you can plate it from the backside and weld all 4 sides ?
  27. Jun 22, 2023 at 6:43 PM
    #1227
    Cruzer
    Cruz
    Sunnyvale, CA
    Balance beads, quick air down, bead grips, and Mickeys.
    They don’t look that big until I look at this picture where I had to take multiple trips to the shop - could only fit 2 in my little Scion Xb :rofl:
  28. Jun 22, 2023 at 6:59 PM
    #1228
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    So, how many sets of wheels ya got now? :)
  29. Jun 22, 2023 at 7:45 PM
    #1229
    Cruzer
    Cruz
    Sunnyvale, CA
    I should have 3 but currently have my 39s for street and these 40s for wheeling - need to get another wheel for the spare 40.
  30. Jun 24, 2023 at 10:07 AM
    #1230
    Cruzer
    Cruz
    Sunnyvale, CA
    Had to wait for my extension cord to finally finish this. The first pass actually went on pretty well, definitely penetrated and didn’t even need to do the back side.
    Can’t really fish plate this cuz it butts up against the drop bracket so I decided to add a glob of extra metal on top :rofl: don’t know if that does anything. I just need it to survive this wheeling season.
