Apple Mirroring Help
Discussion in 'Audio & Video' started by TundraTool13, Sep 16, 2021.
  1. Sep 16, 2021 at 11:23 AM
    TundraTool13
    TundraTool13 [OP] New Member
    2020 Tundra Platinum
    I have a JVC KW-Z1000W head unit and it allows for Apple mirror via HDMI cable. I have the cable installed on the back of the unit and I am using a HDMI/Lighting cable to attach to my phone. When I plug in the phone and select HDMI on the head unit nothing comes up but a black screen. All the info and videos I've looked up shows that it should just appear on your head unit screen once plugged in. Is there a setting in the Apple phone I need to change or allow so I can mirror my phone? Thanks in advance for the help.
  2. Sep 17, 2021 at 3:54 PM
    TundraTool13
    BUMP for any kind of help!! lol
  3. Dec 22, 2021 at 6:09 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Did you ever figured it out?
    TundraTool13[OP] likes this.
  4. Dec 22, 2021 at 3:58 PM
    TundraTool13
    Nope never was able to figure it out!
  5. Dec 22, 2021 at 4:24 PM
    BrandonL812
    Brandon
    That suck. I’m thinking bout getting the same radio. have you contacted jvc customer support to see why?
  6. Dec 22, 2021 at 4:26 PM
    TundraTool13
    The radio is amazing!! I have gone that route yet but I should call customer support.
  7. Dec 22, 2021 at 4:32 PM
    BrandonL812
    Brandon
    If you do, please report back. Im interested in what they say or if it an easy fix. I want that screen mirror to work if i get the radio.
    Thanks
  8. Dec 26, 2021 at 3:40 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I had the same problem on my Pioneer 7600. Had it installed about a week ago. I was going thru the process of elimination and found that if I disconnect CarPlay it works. I turned off Bluetooth and WiFi and the iPhone mirroring worked. I don’t need CarPlay and HDMI going at the same time so it works for me.
    BrandonL812 likes this.
  9. Dec 26, 2021 at 4:31 PM
    BrandonL812
    Brandon
    Sweet. I have the z1000w on order and scheduled to be deliver before the 31st.
  10. Dec 27, 2021 at 12:15 PM
    BrandonL812
    Brandon
    There’s someone on youtube that commented regarding this mirroring issue also. He said he had to use the 1080p hdmi cable. NOT the 4k cable. Once he switched, his mirroring works and carplay also works at the same time. So, i would try a different hdmi cable and see.
  11. Dec 27, 2021 at 12:28 PM
    jeffw6236
    Jeff
    San Antonio
    Thanks Brandon. I’ll give that a shot and see what happens.
  12. Dec 28, 2021 at 1:51 PM
    TundraTool13
    thanks I will try all of this and see what happens.
    jeffw6236[QUOTED] likes this.
  13. Jan 2, 2022 at 6:36 AM
    BrandonL812
    Brandon
    It is confirmed. I installed this radio and it work with the 1080p full hd hdmi cable. I have the firestick hook up here. Youtube also work while screen mirroring using lightning/hdmi adapter cable.
    Youtube is pulled up on Amazon firestick in photo belwo.
    70C51629-165F-47E4-B49D-04ECD81666D6.jpg DAA176F5-4192-458C-8FCC-73151427807A.jpg
  14. Jun 17, 2023 at 6:06 AM
    Saseaman75
    Saseaman75 New Member
    Scott
    2017 tundra Crewmax Platinum
    Lift suspension, TRD Pro Grille, TRD rims and exhaust
    Do you know what specific hdmi cable you were using. Can it be a 1080p/5k. I’ve been trying to get mine to work and can’t figure out and use their recommended hdmi. Any help would be appreciated along with any phone settings and system settings
  15. Jun 17, 2023 at 6:12 AM
    BrandonL812
    Brandon
  16. Jun 17, 2023 at 6:19 AM
    Saseaman75
    Scott
    Thanks for the reply. Guess even factory one doesn’t work.
    I have been trying to figure this out for over a year.
    Are you just using fire stick and not going through phone with fire stick hooked directly to hdmi
    appreciate any help as getting ready to go on a long road trip with boys and video will help in the truck
  17. Jun 17, 2023 at 6:22 AM
    BrandonL812
    Brandon
    Yup. Tether your internet to the firestick. That way your phone is freed up. But you can also mirror it using the apple hdmi adapter also.
    I've done both. Both works great.
  18. Jun 17, 2023 at 8:55 AM
    Saseaman75
    Scott
    THanks for your help.. Hard to believe that the Factory HDMI Cable the unit calls out that you purchase extra doesnt work. So I am goinng to try this.. HDMI Screen just pulls up black as if its not getting a input.. Tried real quick using a ROKU express set up and still same so I will try swapping out the cable. Is there any other settings in the Headunit that I need to worry about if I am just doing a roku or Firestick
  19. Jun 17, 2023 at 11:34 AM
    Saseaman75
    Scott
    swapped the cord and Roku works now- thanks for your help as this has been driving me crazy for a year. Shame jvc hdmi cord recommended didn’t work
    BrandonL812[QUOTED] likes this.
