Bad road = blocked tailgate ... ?
Discussion in '3rd Gen Tundras (2022+)' started by Balzac, Jun 15, 2023.
  1. Jun 15, 2023 at 2:01 PM
    Balzac
    Balzac [OP] New Member
    L
    2023 Tundra Limited CrewCab, TRD OR
    Tonneau cover, added layer of ice, mud or dust
    After a short trip on a riled mountain dirt road, the tailgate could not get opened without brutal force. After a few forceful manoeuvres it now OK. It seems that the tailgate slightly shifts to the passenger side, and jammed the lock on its left. The truck is new, is it a manufacturing defect?, any similar experiences?
  2. Jun 15, 2023 at 4:55 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    How do the gaps between the sides of the tailgate and the bedsides look? Are they square? You said it shifts to the passenger side…is it hitting the bedside? Is the issue just in the hinge, or is something impeding the piston that lets the tailgate down slowly?
  3. Jun 16, 2023 at 10:06 PM
    Balzac
    L
    Thanks for your questions. I double checked, measured the tailgate gaps, on the side and at the bottom. Everything seems square and fine. The issue was not the piston, as I the other day had trouble to unlock the tailgate. Here is a picture of the left lock striker, showing use on its the rightmost end.
    The only thing I notice is that the hinge on the R side, is slightly wobbly. This hinge allows to pul up the tailgate when it about 45° from vertical and unhook it. However I did not drive so steep up!
  4. Jun 20, 2024 at 5:03 PM
    Balzac
    L
    Glad it did not happen again, for more than a year.:):fingerscrossed:
