Rear axle
Discussion in '2.5 Gen Tundras (2014-2021)' started by tristonrose, Jun 15, 2023.
  1. Jun 15, 2023 at 7:18 PM
    tristonrose
    tristonrose [OP] New Member
    Heath
    2014 Tundra SR5 4×4
    Can anyone tell me what that pin or bar is that is preventing me from putting my rear axel back in. I know it's blocking it because I took a measurement. Please help! Thanks!
  2. Jun 15, 2023 at 7:41 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    That’s the carrier. You can’t go past that. Sounds like you’re missing something.
  3. Jun 15, 2023 at 7:42 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That's the cross shaft pin, are you trying to install the same axle you took out?
  4. Jun 15, 2023 at 7:47 PM
    tristonrose
    Heath
    2014 Tundra SR5 4×4
    Yes same axel. Thing is I need like an 1 1/2 from being all the way in so I took a measurement and it seems that's what is holding me up?
  5. Jun 15, 2023 at 7:56 PM
    TILLY
    Massachusetts
    You're probably just getting hung up before it slides in all the way, sometimes its a bitch. Try sliding it in, and near the end put pressure downward while pushing to keep the axle in the center of the tube. Good luck.
  6. Jun 15, 2023 at 8:58 PM
    tristonrose
    Heath
    2014 Tundra SR5 4×4
    Cruiser, what do you mean by missing something? Your saying that pin is called the carrier? I very well could be wrong but man I really feel like I'm hitting it. The measurement I took seems to confirm it?
  7. Jun 15, 2023 at 10:22 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    if ur measurement is right then it's the wrong side axle.
  8. Jun 16, 2023 at 3:34 AM
    Cruzer
    Cruz
    Sunnyvale, CA
