5.7 engine air filter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sonicbluerider, Jun 14, 2023.
  1. Jun 14, 2023 at 11:23 AM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    Omg just bought a new one from Toyota dealer. There about 1/2 as deep / thick but same price. Sure hope they work as well
  2. Jun 14, 2023 at 11:27 AM
    2mchfun
    Doesn't that mean there's less filter material or pleat width?
  3. Jun 14, 2023 at 11:28 AM
    I believe they have a couple different part numbers that are compatible.
  4. Jun 14, 2023 at 11:37 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Yep . parts department said that's what they are selling now
    Tundra234 likes this.
  5. Jun 14, 2023 at 12:01 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Just keep an eye on it and swap out for a new one more often if needed.
    WILLINH likes this.
  6. Jun 14, 2023 at 12:08 PM
    pursuit2550
    pursuit2550 New Member
    I buy WIX from Amazon. They are around $17. What's the dealer price on the OEM?
  7. Jun 14, 2023 at 12:32 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Do you have a picture? I bought like 5 filters a while back during a sale and they were the same as the factory one.
  8. Jun 14, 2023 at 12:34 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Im thinking of doing this. Can you post your filter also for reference?
  9. Jun 14, 2023 at 12:44 PM
    MadMaxCanon
    This is the one I got 17801-0P100.
    Shanet421[QUOTED] likes this.
  10. Jun 15, 2023 at 10:37 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    In iowa $30 00
  11. Jun 15, 2023 at 10:49 AM
    2mchfun
  12. Jun 15, 2023 at 10:53 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Does a foam liner come with it?
  13. Jun 15, 2023 at 10:56 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I got that one as well, it looked like a factory one in MY2019. Besides the color.
    MadMaxCanon[QUOTED] likes this.
  14. Jun 15, 2023 at 11:04 AM
    2mchfun
    Not really foam, more like a polyester secondary filter material. Keeps more debris out of the pleated area.
    Jaypown[QUOTED] likes this.
  15. Jun 15, 2023 at 11:32 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Is it just a Wix brand thing then? I’ve never seen others with that included. I usually just get a random one off of Amazon.
  16. Jun 15, 2023 at 11:35 AM
    MadMaxCanon
    for whatever reason, the colors from the factory are different for the exact same thing for certain things. Another example of this i found is that the factory power steering fluid in my truck is not colored red (its clear like new brake fluid) like the replacement power steering fluid that is red.
  17. Jun 15, 2023 at 11:39 AM
    2mchfun
    I don't know, don't buy too many air filters since my truck is pretty low mileage.
  18. Jun 15, 2023 at 12:12 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    If I recall, my original filter had it, as did the replacement Napa filter I used at the time.
    DoublePro and 2mchfun like this.
  19. Jun 15, 2023 at 12:16 PM
    2mchfun
    Wix makes Napa filters
    DZ_[QUOTED] likes this.
  20. Jun 15, 2023 at 12:18 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Yep. I've liked Wix stuff. I couldn't find one in stock at the last change and had to use an off brand. Thanks for posting, just order one and a cabin air filter for the next maintenance.
    2mchfun[QUOTED] likes this.
  21. Jun 15, 2023 at 12:20 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Interesting. Light green is Pentosin CHF-11S, red is usually ATF?
  22. Jun 15, 2023 at 1:12 PM
    MadMaxCanon
    It definitely was not light green in the power steering reservoir from the factory. The toyota fluid that I used is ATF & power steering fluid and its red
  23. Jun 15, 2023 at 1:23 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I went down a worm hole trying to figure out the correct power steering fluid. Part number and more info in this thread.
    https://www.tundras.com/threads/oem-power-steering-fluid.108836/
  24. Jun 15, 2023 at 1:26 PM
    MadMaxCanon
    I used the same stuff you did. In fact, your thread may have been why. That stuff is NOT easy to find though, at least it wasnt for me.
    Joe333x[QUOTED] likes this.
  25. Jun 15, 2023 at 1:35 PM
    Joe333x
    Joe333x Member
    Boston
    When I need parts I just go to the Toyota parts website, put in the number and find the dealer who has it for the best price, they typically offer free shipping over $75.
    https://autoparts.toyota.com/products/category/parts
  26. Jun 15, 2023 at 1:38 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It is very-very light green when new and turns transparent quickly.
  27. Jun 15, 2023 at 1:39 PM
    MadMaxCanon
    i changed it at 25k miles so makes sense why it wasnt light green.
  28. Jun 15, 2023 at 1:45 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In these steering racks with green fluid you do not want ATF, it will foam and cavitate in the PS pump, wearing it's wanes. Probably the fluid spec can't be judged by the color alone, but still make sure it's a correct spec fluid.
  29. Jun 15, 2023 at 1:52 PM
    Joe333x
    Joe333x Member
    Boston
    The correct fluid is ATF Dex II or III, part number is 00718-ATF00.
    MadMaxCanon likes this.
  30. Jun 15, 2023 at 1:57 PM
    MadMaxCanon
    The fluid used in the above linked thread is the correct one. Manual stipulates ATF dextron 2 or 3.
