Dash lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Mstates1984, Jun 15, 2023.
  1. Jun 15, 2023 at 9:42 AM
    Mstates1984
    Mstates1984 [OP] New Member
    2008 5.7 double cab
    This has been happening since I bought the truck in November.
    4hi light flashing, traction control light on, vsc light on, and abs light on....this happens in wet conditions only. I had a front wheel sensor replaced, but didn't solve the issue. It doesn't happen all the time when wet, but definitely only happens when it is raining or going in snow... This has not happened since the weather cleared up (Erie pa) but his the other morning on my way to work, it was raining and they all came on... Once the truck sits for a little bit, they go away. It doesn't not seem to affect the performance but I worry come winter time it will happen all the time and I am not sure if it will disengage my tcs and 4wd....
  2. Jun 15, 2023 at 10:30 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    here’s a cheat sheet but I’m not seeing the exact same combo of lights that you listed.
