2012 sequoia platinum rim options
Discussion in 'Wheels & Tires' started by OVRLND, Jun 15, 2023.
  1. Jun 15, 2023 at 6:56 AM
    OVRLND
    OVRLND [OP] New Member
    2012 Sequoia Platinum
    Looking to start building my 2012 Sequoia Platinum.
    Looking around on FB marketplace and found a set of 18" TRD pro rims which I know fit fine.
    Also can across these black 18" Lexus rims
    I do like the look of them and obviously would swap the tires for some larger ones. Any reason why they wouldn't work? See attached image.
  2. Jun 15, 2023 at 9:06 AM
    Those are likely from a Lexus car based on the tire size. Bolt pattern is different. The cars have a 5x4.5 instead of the Tundra and Sequoias closer to 5x6
    Saltyhero13 likes this.
