Does 2006 4.7L have a MAP sensor?
Discussion in '1st Gen Tundras (2000-2006)' started by 06ToyoTundra, Jun 12, 2023.
  1. Jun 12, 2023 at 9:11 PM
    06ToyoTundra
    06ToyoTundra [OP] New Member
    2006 Tundra SR5 4WD XCab
    Does a 2006 4.7L have a MAP (Manifold Absolute Pressure) sensor? I know is got a MAF (Mass Air Flow) sensor. Rock Auto lists them & I find their listings are normally very reliable. But I can’t locate a sensor that looks like their listings under my hood. I haven’t been able to find a definitive answer on this forum or on Google searches either.
  2. Jun 12, 2023 at 9:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    AFAIK, these trucks don't have a map sensor as a single unit. I think they are built into the vapor canister if we have one at all???
    I am also talking out of my ass sorta
  3. Jun 12, 2023 at 10:43 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    no MAP. just a MAF sensor.
    snivilous and DJenerated like this.
  4. Jun 13, 2023 at 2:38 PM
    06ToyoTundra
    Why do you think Rock Auto, Advance Auto, O’Reilly, AutoZone, & even Toyota.com parts all have listings for MAP sensors for it? I guess they might all be using the same search engine? Did Toyota eliminate the MAP sensor when they went to the VVT engine in 2005 or did they never have one?
  5. Jun 13, 2023 at 2:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If you're meaning for a 2006, happen to have the Toyota part # ?
  6. Jun 13, 2023 at 3:01 PM
    06ToyoTundra
    The parts stores list Denso part # 198-1003 or 1981003 and other brand options. Toyota.com parts lists 89421-71010
  7. Jun 13, 2023 at 7:17 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Iirc the 05+ vvti 4.7 has a map sensor because it has the variable length runner intake manifold.
    It also has a MAF.
  8. Jun 13, 2023 at 8:04 PM
    06ToyoTundra
    By “05+” I assume you mean the 2005 & 2006 4.7L have MAP sensors. If so, can you tell me where it’s located?
  9. Jun 13, 2023 at 8:31 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yes, 2005 & up VVT-i 4.7L.
    I think it's on the pass side of the intake manifold but could be fender or firewall mounted. I don't recall off the top of my head.
  10. Jun 14, 2023 at 7:41 PM
    06ToyoTundra
    I looked everywhere again including the passenger side of the intake, the fender, & firewall. I even climbed in the engine compartment to check on the back of the intake. I can’t find the damn thing!
