Oil pressure
Discussion in '2.5 Gen Tundras (2014-2021)' started by David18921, Jun 10, 2023.
  1. Jun 10, 2023 at 8:56 AM
    David18921
    David18921 [OP] New Member
    Just curious about if my oil pressure is normal. When I start my truck it rises to about 3/4, then drops down to about just under half. I’ll rise slightly above have if I get on the throttle but most of the time it is below. I know it is barely even noticeable but it is still low. Is this just because of my oil heating up?
  2. Jun 10, 2023 at 9:10 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Completely normal. That's where they all sit when warm, half to slightly under.
    FirstGenTundra likes this.
  3. Jun 10, 2023 at 10:10 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    My 2014 does this too, high pressure on start up and sits roughly at halfway mark once warmed up.
  4. Jun 10, 2023 at 10:12 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    100% normal
  5. Jun 10, 2023 at 10:15 AM
    mustangr2
    mustangr2 New Member
    Yeah normal.
  6. Jun 10, 2023 at 10:19 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    When cold the oil pump will build pressure until the relief valve opens up, then the pressure settles into the normal range. Perfectly normal.
  7. Jun 10, 2023 at 11:30 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Normal with 0w20 and 5w30. When i run 15w40 in the summer it actually sits in the middle.
  8. Jun 10, 2023 at 11:33 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Same as what I get.
  9. Jun 12, 2023 at 5:48 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    A worthless gauge like most oem oil pressure gauges because people would unnecessarily freak out if it showed real data
  10. Jun 12, 2023 at 8:56 PM
    MadMaxCanon
    Been thinking to do that myself. Notice any difference in how it runs?
  11. Jun 12, 2023 at 9:39 PM
    Joe333x
    Joe333x Member
    Boston
    I only had 0w20 in it when I bought it and then changed it soon after for 5w30. 5w30 is definitely much quieter than 0w20 but in the summer and after it has around 3000 miles on it then you start to hear that tick. With 15w40 it stays nice and quiet all the way til I change it out at the end of the summer.
  12. Jun 13, 2023 at 3:07 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    This is where my 2020 (0w20) runs at Operating Temperature.
  13. Jun 13, 2023 at 4:58 AM
    MadMaxCanon
    Do you run full synthetic? what kind of driving do you typically do? I.E. highway, short city, offroad, etc.
  14. Jun 13, 2023 at 7:46 AM
    Joe333x
    Joe333x Member
    Boston
    I run Mobil 1 5w30 and Rotella T6 15w40. All mixed driving between short trips and highway, no offroad
    MadMaxCanon[QUOTED] likes this.
  15. Jun 14, 2023 at 10:44 AM
    jdl25
    jdl25 New Member
    Mine looks exactly like that.
    Side note, I like your F to E indicator. I wish mine was there more often.
  16. Jun 14, 2023 at 4:19 PM
    David18921
    Haha yea it only cost me my left nut to get it there though
