Leaf spring options
Discussion in '2nd Gen Tundras (2007-2013)' started by TEF1701, Jun 13, 2023.
  1. Jun 13, 2023 at 6:54 PM
    TEF1701
    TEF1701 [OP] New Member
    Travis
    Spokane, WA
    2010 Tundra Grade
    The other day I noticed that my leaf springs look more like a “W” than a nice arch. Pretty much everyone on the forums says they’re toast. After burning out my brain spending a couple of hours researching leaf springs, including the forums, does anyone have any suggestions for good quality leaf springs that won’t break the bank? I want to keep as close as possible to stock ride height, but a little lift is okay too (no more than 2”). I would also like better performance under load and longer life than the piece of crap stock springs. My truck only has 80k miles, so seeing flat springs is honestly kind of shocking.
  2. Jun 14, 2023 at 4:49 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Hmmmm....... FWIW My '07 has 87K, still sits level and rides like the day I drove it off the dealers lot. My rear leafs are also "flat" - I don't know that they ever had an "arch"... I installed air bags years ago, to level the truck with a horse trailer or my RV hooked up. Good luck.
  3. Jun 14, 2023 at 5:45 AM
    The Tundras springs don't have much arch to them. Mine on my 2020 were bad at 13k miles. They creaked really loud and had about 1/4 inch gaps between the leafs. I replaced mine with Alcans.
    Krewcial likes this.
  4. Jun 14, 2023 at 8:32 AM
    TEF1701
    Travis
    Spokane, WA
    2010 Tundra Grade
    I’ve read good things about Alcans. I’ll check them out. These are my driver side springs. There is almost no arch at all. There is no way this is normal.
  5. Jun 14, 2023 at 8:45 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I am fairly certain that the distance from center of hub to top of wheel well (see pic below) is 25” from the factory. My truck’s leafs looked like they had a negative arch like the W you are describing, but that distance was indeed 25” for me when I measured it at 115k miles on the springs.
    edit: oops, forgot pic :rolleyes:
  6. Jun 14, 2023 at 9:15 AM
    TEF1701
    Travis
    Spokane, WA
    2010 Tundra Grade
    I have 23” from center of hub to wheel well, so even new factory springs would give me 2” of lift.
  7. Jun 14, 2023 at 9:17 AM
    If you look under Tundras that you see in parking lots you will see that this is quite common.
  8. Jun 14, 2023 at 9:20 AM
    TEF1701
    Travis
    Spokane, WA
    2010 Tundra Grade
    If I started crawling under trucks in my town, I’d probably get arrested. :rofl:
  9. Jun 14, 2023 at 9:30 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Having flat springs is a common Toyota issue… however, if you want something that works well and doesn’t break the bank then we recommend the Icon RXTs (and conveniently we have them on sale here at Hotshot Offroad). You’d get about 1.6-1.75” of rear lift out of them. They do like to get noisy though and we also have an easy fix for that too! You’d be in new springs and U-bolts for less than $700 shipped.
  10. Jun 14, 2023 at 9:48 AM
    True....for attempted cat theft. :rofl:
  11. Jun 14, 2023 at 9:50 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I’m a big fan of sumo springs in this situation. The OEM springs and alot of aftermarket springs will eventually sag with or without a static load (but way faster with a static load/filling to capacity). The sumo springs just barely make contact with the OEM springs when unloaded and help prevent sagging. Recently I put in Dobinsons leaf springs with a 2” lift then added another 2” of sumo springs to also have constant support for loads. Install is quick and they have no maintenance whereas air bags are superior in ride/control but have more maintenance/setup (just tradeoffs).
  12. Jun 14, 2023 at 9:52 AM
    How much are the Sumos? I'm wondering if I should get some for my Alcans.
    Now that I'm thinking about it, I have Timbren bump stops so I don't need Sumos?
  13. Jun 14, 2023 at 10:00 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Oh for sure, the most common setup is part number SSR-610-40 and are usually 250-300$. Those are 1000lbs (blue) at half compression so are the softest, then there is a 1500lb (black) version and even more like 3000lb (yellow). Alot of people will say don’t reuse your leaf shackles as they stretch when torqued the first time (so consider getting new shackles if that is a concern). These will make the truck ride more stiff when unloaded, as there is much more support (somewhat like a sway bar when turning too). I’ve had these on two tundras for 100k miles and like it that way haha.
  14. Jun 14, 2023 at 6:56 PM
    lake
    lake New Member
    rockauto had some OEM for a good price. I got mine from junkyard from a truck with 45k miles and i don't have an arch either
  15. Jun 14, 2023 at 7:11 PM
    TXHUNTER85
    TXHUNTER85 New Member
    2015 Tundra Crewmax
    6112/5160, air ride 5000, icon add a lead pack, Icon Wheels, 285/75r17 Toyo at3, trd sway bar
    I am having some Ironman HD springs put on my truck as we speak. Keep a decent load in the back constantly and will have a camper shell soon as well. We will see how they do.
  16. Jun 15, 2023 at 9:47 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Hmm..I’ll be in Missoula in a couple weeks? Mine are beyond flat!
  17. Jun 15, 2023 at 9:56 PM
    memario1214
    Colton
    Missoula, MT
    Hit me up via pm or call us here (406-936-0206) and if you want to get something knocked out we probably could!
    MTRock[QUOTED] likes this.
  18. Jun 16, 2023 at 3:17 AM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    I went with Alcans, airbags, cradles and dobinson greaseable shackles. I even reached out to @Tundra234 before hand on the ride quality.
    I’ve only had everything installed for 2 weeks but took a dirt road at about 55 mph after install and boy did these leaf’s perform. Also yesterday there was a good stretch of concrete highway that’s known to cause the infamous bed bounce. I could see the bed wanting to start bouncing but the rear end held up and rode smooth.
    Overall I’m extremely happy with the ride quality and so far no squeaks or noise coming from my rear end.
    Ricos, WVI and Tundra234[QUOTED] like this.
