  1. Jun 9, 2023 at 10:14 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It'll be fine. I'm assuming it's saying no since it's not pressure treated but if you're painting it anyway there's no issue.
    FirstGenVol[QUOTED] and Winning8 like this.
  2. Jun 10, 2023 at 2:50 PM
    AZTundra
    Paul
    Phoenix, AZ
    Picked up the pine tongue and groove boards today from the lumber yard for the patio ceiling project. Next will be sanding them all down with 220 grit before applying prestain conditioner, stain, and polyurethane. 20230610_143719.jpg
  3. Jun 10, 2023 at 7:08 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    What kind of tree is that wood from? I’d use a hardwood if painted. My preference would be pressure treated or cedar tho.
    TaquitoBandito likes this.
  4. Jun 11, 2023 at 11:10 AM
    Moen bathroom faucet- removed / replaced the screen filter. Water pressure for the wife’s side is much better
  5. Jun 11, 2023 at 11:17 AM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    With a diamond plate cover
  6. Jun 12, 2023 at 8:01 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    After spending too much time purchasing material the past couple months I believe it's safe to say, that WASN'T cheap.
  7. Jun 12, 2023 at 8:08 AM
    Outbound
    Aaron
    Northern Alberta
    I stumbled into a clearance sale on fire brick last week, so I rebuilt our firepit. I just need to build a new spark screen.
  8. Jun 12, 2023 at 10:00 AM
    AZTundra
    Paul
    Phoenix, AZ
    Not sure how the prices compare with inflation, but I paid roughly $760 for the wood including tax. This was 38 boards 16' long and 6" wide so 304 square feet total. I plan to do the staining and polyurethane myself (sure hope I don't screw it up) and then just pay the contractor for running some electrical and installing the boards to save a little.
  9. Jun 12, 2023 at 11:05 AM
    So both the piece with the X and the white board running horizontally are rotted out. There was no step flashing where the gutter meets the side.
    Is it going to be possible for me to replace the board with the X without pulling the Hardie siding?
  10. Jun 12, 2023 at 11:41 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Cut the nails, should just slide out
  11. Jun 12, 2023 at 2:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Kind of depends on if it’s just a “siding” board over something else or if it’s framing. If it is just a siding board, cut or pull the nails (long slender reciprocating blade) and it should slip out. You may need to pull the gutter though (and I would anyway to inspect/asses what is going on at that intersection). If you replace the rotted face board with fiber cement (Hardie) you want to make sure it’s fully painted before the gutter goes back on, and I’d also add a secondary flashing behind the gutter endcap anyway.
  12. Jun 12, 2023 at 2:54 PM
    It's definitely going to be a learning experience. My 81 year old neighbor is offering to help :D. He's exactly who I hope to be at that age. He's in good enough shape that he built an entire outbuilding last year.
    From what I can see so far, it doesn't look like it ruined anything structural but I'll know later when Bill looks at it.
  13. Jun 12, 2023 at 4:47 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It’s only a fascia board, the structure is at the porch ceiling and wall. Fix the kickout flashing and prime all sides on fascia board.
  14. Jun 13, 2023 at 6:30 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Replaced my dead 7.5 year old Everbilt Home Deput sump Pump with a 1/3 hp rigid and thinking of ordering a Zoehler to keep on my shelf, because I hear they're the one to get. But I always wait to replace until it dies. And it always dies during off hours when there's more water in the ground so I end up doing the easy thing and driving 5 minutes to HD to buy something mediocre to get it running as fast as possible.
  15. Jun 14, 2023 at 5:35 AM
    All this water damage occurred before I had new gutters installed. Previous owners didn't care.
    This is what it looks like now. When it rains today I can no longer feel or see rain running down onto the boards below.
    Would you change anything with this?
  16. Jun 14, 2023 at 7:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It should be install like a 2” higher, so it kick the water out to the gutter and should be inside the siding, you are relying on caulking to seal the kick out flashing to the wall at this point.
  17. Jun 14, 2023 at 9:31 AM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    Can I ask about the under cabinet refrigerator? I have been looking to build a coffee bar and want to put a beverage refer under it, but, trying to find a refer that gets cold enough to keep beer, soda, and water has my head hurting. Most are designed to keep wine cool, not keep other drinks cold.
  18. Jun 14, 2023 at 9:34 AM
    BB Stacker
    So. Cal
    IMG_6053.jpg IMG_5877.jpg Tiled my "shed". I still need to grout, do the case moulding around the door, baseboards, finish up under the eaves, and install rain gutters. Just as an FYI, some of my buddies are telling me it is not a "Shed".
  19. Jun 14, 2023 at 9:45 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That, and if you can, try to slide some new flashing up behind the existing piece before you replace the board.
  20. Jun 14, 2023 at 4:45 PM
    Anyone knowledgeable on AC thermostat wiring?
  21. Jun 14, 2023 at 4:52 PM
    We bought one for sale from HD for $268 and it gets drinks very cold. Believe it’s set on 36° or so.
  22. Jun 14, 2023 at 4:54 PM
    I know it’s color coded and I failed to push my “C” wire far enough into the retainer to make good contact. Spent 30 mins diagnosing an AC that wouldn’t come on just to check my Nest thermostat install from a week ago and find the loose wire. What kind of problem are you having?
  23. Jun 14, 2023 at 4:58 PM
    Finished up the wood rot repair. This was a 3 beer job. It would have been 5 but I started while I was still on the clock at work.
    I just need to sand, caulk and paint.
  24. Jun 14, 2023 at 5:15 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Scraped the top, threw down some weed block and then some rock. My back is sore. Rented a little dingo but it could only help so much. Didn’t really want grass and to have to run sprinkler line so I did rock instead.
  25. Jun 14, 2023 at 5:59 PM
    BB Stacker
    So. Cal
    Better be careful, I've heard dingos will eat your babyhttps://www.youtube.com/watch?v=ghCTZF61ey0
    CodyP[QUOTED] and NewImprovedRon like this.
  26. Jun 14, 2023 at 6:01 PM
    So I replaced my 13 year old wifi thermostat with a new Honeywell Home smart thermostat.
    The old thermostat was wired:
    C is brown
    G is green
    Y is yellow
    W is white
    RC is red
    RH is jumper wire to RC
    The new thermostat is wired:
    C is brown
    G is green
    Y is yellow
    W is white
    R is red.
    Looking at the jumper wire image, I moved the wire from RC to the R. If i understand correctly, R and RC on the new thermostat is the same as RC and RH on the old one. The 2nd pic is the old thermostat and the 3rd & 4th is the new one. Orange and blue and black are not used.
    KNABORES[QUOTED] likes this.
  27. Jun 14, 2023 at 7:04 PM
    I updated the post. I think I have it wired correctly now. :fingerscrossed:
  28. Jun 17, 2023 at 11:55 AM
    NWPirate
    Zach
    WA
    Just finished a little fort for my kids. The platform is 5' up, chalkboard paint down below with a 8' climbing wall.
  29. Jun 17, 2023 at 1:08 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Hey Stacker, it's some off brand 2 drawer fridge I found on Amazon.
    When I was in CO last September helping our neighbor build the fence between our properties I noticed they have one, and how awesome and convenient it was. Thought it would be perfect for the coffee bar as all the 500+ creamers and crap that my wife insists on having now live in the top drawer instead of hogging up our whole fridge. My beers live in the bottom drawer.
    Having said that, they're not cheap but we love it.
  30. Jun 17, 2023 at 2:23 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    So I live on a private dead end street. And people use my driveway to turn around when no one is home. The problem is there’s a lot of assholes they don’t care about other people property and those assholes end up driving on my lawn.
    The bucket truck did some real damage.
    So I finally got around to at least preventing it from happening.
    IMG_9035.jpg 70871835741__22B0CA6A-9D13-439F-9661-3F1845E38B87.jpg IMG_9037.jpg IMG_9038.jpg
    There’s a big yellow pole that goes in there and locks in. It’s removable for when I need it to be.
    This will at least make drivers pay attention to what they’re supposed to be doing.
