Spod vs switch pro
Discussion in 'Lighting' started by cctxquicksand, Nov 1, 2020.
  1. Nov 1, 2020 at 12:51 PM
    cctxquicksand
    cctxquicksand [OP] IG - TRDistheWrd
    Which one and why?
    my last build I ran to individual switches, while it looked ok it was a big hassle running all those wires. This time around I’m looking to simplify things with one of the two mentioned units. Upon first glance I’m really leaning towards the spod, to me it just looks much cleaner and simpler than the switch pro system. If I went spod I would grab the lcd screen to go with so if anyone has feedback around that screen please let me know as well. Thanks for the feedback
    Did a search couldn’t really find much so pardon me if this has been discussed before
  2. Nov 2, 2020 at 8:23 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I have the sPod with the 6 switch panel in the overhead sunglass holder and I love it! I agree as far as the spod being simpler, it was a super easy install. my neighbor has the spod with the screen in his RZR and its bad ass! makes me wish I got the LCD screen too but being I have the front bench seat I don't know where I would mount it.
  3. Nov 2, 2020 at 8:36 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Not sure what kind of settings are on the spod but with switch pros you can make your lights strobe, dim, and can control them from your phone as well.
    cctxquicksand[OP] likes this.
  4. Nov 2, 2020 at 8:41 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I had this same question and ended up going with the Switch-Pros. I also got the SDHQ mount and couldn’t be happier. The mount was pretty easy and the functionality as well a the ability to customize was what pushed me to the Switch-Pros.
    shellshock and cctxquicksand[OP] like this.
  5. Nov 2, 2020 at 1:25 PM
    cctxquicksand
    I think I’m going to go with the spod due to the simplicity. The new bantam has strobe and dim capabilities. I really liked the switch pro up until I saw all the bare wires you need to butt splice.
    also all the threads and articles I can find online seem to have switch pros as the more advanced system ( not an electrical guru so not really sure on specifics as to why) but these were from 2018 and prior. Hard to find any updates information comparing the two. I’d imagine spod has caught up by now?
  6. Nov 2, 2020 at 1:50 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    If you want ultra simplicity look at the trigger wireless. No wires through the firewall.
    Only had it since April but zero issues
  7. Nov 2, 2020 at 2:17 PM
    cctxquicksand
    This looks like a winner. Thanks for the suggestion
    Flyinryank[QUOTED] likes this.
  8. Dec 24, 2020 at 2:25 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    I was fixing to run all kinds of wires and switches into cab of truck till I ran across your post. This system simplifies everything. Fixing to order it, thanks for educating me. :hattip:
  9. Dec 24, 2020 at 2:36 PM
    cctxquicksand
    I ended up going with the trigger system. Works flawlessly and was super simply to set up. Highly recommend
    Clemshady and FrenchToasty like this.
  10. Dec 24, 2020 at 3:04 PM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    I looked at all 3 options but honestly thought they were a bit bulky or too much wiring. I only needed 3 switches and thought it was much easier and take less room to simply run 3 small wires from the engine bay into the cab. All other power, ground and such wires are already in the cab. Simple setup with minimal wiring under the hood.
    MDJK likes this.
  11. Dec 24, 2020 at 5:03 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Very happy with my S Pod system.
    GWill likes this.
  12. Dec 25, 2020 at 10:47 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I just bought and received the trigger wireless system because of this thread.
    I have 4 sets of lights to use but I went with the 6 trigger system for ease of expansion later if I get a fridge or on board air.
    I can’t believe how easy thins thing is to use and install
  13. Dec 26, 2020 at 6:48 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Can you put the switches in an existing panel or are you stuck with theirs ?
  14. Dec 26, 2020 at 7:26 AM
    cctxquicksand
    I believe you can run your own switches but then it kinda defeats the whole wireless aspect of the install. I have the six shooter and the switches fit inside my sunglasses spot. I honestly don’t even use the switches and they have an app that lets you control the switches, it also includes strobe and dim through the app. The switches are programmable to be any color you want as well you just have to wire power to them
  15. Dec 26, 2020 at 8:24 AM
    rockmup
    rockmup New Member
    Todd
    Thanks but I didn't ask about using my switches, I asked if their switches will fit in an existing panel. They look to be the size of carling switches. Do you happen to have a pic of the back side of the panel ?
  16. Dec 26, 2020 at 8:37 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    most OEM looking switches out there
  17. Mar 7, 2022 at 6:02 PM
    thedonn
    thedonn New Member
    How do you like the SPOD? I just put mine in and I love it. there doesn't seem to be much info on this model. The only issue I have is the bluetooth range doesn't seem great
  18. Mar 17, 2022 at 11:28 AM
    jasoncda
    jasoncda New Member
    2019 Tundra TRD pro black
    For those of you with the trigger setup, did you guys fuse it to the starter so it only runs when the engine is on? If not, is the drain on the battery going to be an issue?
  19. Mar 17, 2022 at 1:12 PM
    cctxquicksand
    I’ve been running straight to the battery since I bought the unit and have never had an issue with the drain
    jasoncda likes this.
  20. Mar 17, 2022 at 1:18 PM
    jasoncda
    jasoncda New Member
    From what it looks like, it seems like the only thing that would have drain is the wireless receiver on the unit which is probably super minimal. Looks like such an easy system to set up though! Thanks for the reply!
  21. Mar 17, 2022 at 2:38 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Is it worth me getting either one of them , if i'm only running Baja S8 lightbar and ditch lights?
  22. Mar 17, 2022 at 2:42 PM
    cctxquicksand
    In my experience you will pay someone more to wire your light bars vs buying a trigger and doing it yourself
    also the strobe and dimming features are pretty awesome
    alb1k likes this.
  23. Mar 17, 2022 at 2:50 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I think so. I doubt that's all you will ever run. I'm currently using 4-5 and can easily see 8
    hi_rawb[QUOTED] likes this.
  24. Jun 13, 2023 at 8:03 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Interesting read for sure. I’m still not sure if either is for me. Going solely on the purpose of the vehicle, it’s a mostly daily driver but certainly long distance travel especially at night
    Outside of lighting I don’t know if the juice justifies the squeeze
  25. Jun 13, 2023 at 8:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Ditch lights
    Front Light bar
    Chase lights
    Rock lights
    Disco stick
    Air compressor
    Radio power
    Refrigerator
    right there you’ve got all 8 spots of a SwitchPro 9100 used up and haven’t even done running lights or aux power for the tent or camp mood lighting
    :thumbsup:
    everyone’s use case is different
    I’ve currently only got two spots in use in my SP9100 but have already planned for three more.
