Platinum or TRD Pro ?
Discussion in '3rd Gen Tundras (2022+)' started by Steelhant, Jun 10, 2023.
  1. Jun 10, 2023 at 5:19 AM
    Steelhant
    Steelhant [OP] New Member
    TRD- Pro
    none...new
    I purchased 2023 Platinum and the only thing I don't like, call me crazy, but the ride is too soft . I have the long bed the rear traction seems a little loose, like not that stable...Wish it would feel the road better...The other thing that was strange I drove over some highway roads that had lines cut on the concrete pavement, I guess for drainage...they looked about few inches apart and the truck would not stay straight...like swaying..plus on a highway trip NJ to Penn ... 120 miles ..70-75mph I did get 20.7mpg
    Does the TRD Pro have a much different highway ride ?
    Thanks,
    Chuck
  2. Jun 10, 2023 at 5:40 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Do you have AVS? I would bet the Pro would be a little bit softer. I find the ride on my Platinum to be great, but it’s on the stiffer side. I’m sure the long bed makes for a softer ride with the longer wheelbase and weight. I would recommend just upgrading your shocks if that’s an option
  3. Jun 10, 2023 at 6:00 AM
    ScoobyDoo27
    ScoobyDoo27 New Member
    Utah
    2022 Tundra Platinum 4x4
    My platinum does the same thing with roads that have the grooves in them. I think that comes from the tires more than the truck itself. I’m just not going to change tires till these ones wear out.
  4. Jun 10, 2023 at 6:56 AM
    Steelhant
    TRD- Pro
    none...new
    Thanks for the responses. I also think it could be the tires... I don't have AVS...so I'm really not sure...maybe shocks could be the answer..
    Just seem to loose rear grip, like bouncing, not sure footed on a corner...not happy with that, but overall the truck is great.
    Thanks again,
    Chuck
  5. Jun 10, 2023 at 7:12 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    It’s called road tining and some tires causes this due to the tread patterns. I had same issue with oem Bridgestone. Issue went away when I swapped to the Toyo At3.
    I test drive many vehicles at my job as a tech and depending on tires installed, some sway worse then others, no matter the brand. Our test route takes us on interstate 78 where it’s mostly concrete road tining and I notice the sway issue happen especially with HT tires.
  6. Jun 10, 2023 at 8:44 AM
    Tom
    Tom New Member
    Your tires and all other tires are just tracking the groove in the road. Normal. Yes the platinum shocks are soft. The difference between the Trd Pro and platinum are night and day. One cost about $200 each and the other is like $800
  7. Jun 10, 2023 at 8:52 AM
    Steelhant
    TRD- Pro
    none...new
    That's where i went yesterday, friend picked up a TRD Pro Four Runner and it was Rt. 78...with the Platinum do you recommend the Toyos or others...Almost seems like a tires going flat ...It's was really bad !!
    Thanks,
    Chuck
  8. Jun 10, 2023 at 8:54 AM
    Tom
    Tom New Member
    Try turning of Lane Trace.
  9. Jun 10, 2023 at 11:13 AM
    Kawaski pro mule 22
    Kawaski pro mule 22 New Member
    East Texas
    22 model tundra 1794 MGM
    None
    Try the groved highway on a motorcycle. Wow
    doublethebass likes this.
  10. Jun 13, 2023 at 6:42 AM
    cdq85
    cdq85 New Member
    Corey
    Greensburg,PA
    2022 TRD Pro Tundra
    I've had a Limited, Platinum and a PRO. I am going straight back to a Platinum next week when it gets here.
  11. Jun 13, 2023 at 6:47 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    I’ve had a platinum and a pro. Pro is only worth the resale value and out of the box paint match. Other than that it’s not worth it. Especially the non discounted 74-78k price tag average I’m seeing.
    my 22 pro was 69k. Was worth it then. Sold it for $82k. Bought a 23 platinum with AVS for 70k it was a lot better. The AVS makes a huge difference in comfort. The steering is better, the black headliner is better, seats were negligible although I would say I like the softex material better because of wearability. Platinum ambient lighting is nice. Platinum turn radius is far better. TRD pro is turribull with steering.
    nodak67 likes this.
  12. Jun 13, 2023 at 4:04 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I agree with Dr Z, I had a 22 Limited OR and the softex seats were better than my 23 Plat leather. They both had heated and cooling features, but plat has the thigh support and maybe that is the difference. Seems like an extra bar across the bottom.
