02 Tundra Overhaul
Discussion in '1st Gen Builds (2000-2006)' started by boto_flea, Jun 11, 2023.
  1. Jun 11, 2023 at 10:10 PM
    boto_flea
    boto_flea [OP] New Member
    2002 Tundra 4wd
    Howzit guys,
    New member here and figure I document the overhaul of my recently acquired 1st gen. Bought it back in January for much more than it’s worth and started to make it “driveable”. My current plan is to completely rebuild the interior, suspension and engine. I don’t care much about the body as it will be used mostly as my hunting/adventure rig and I’m sure I’ll be thrashing here and there. Here’s what we starting with…
  2. Jun 13, 2023 at 1:56 PM
    boto_flea
    2002 Tundra 4wd
    Started with the front suspension. I live in Hawaii so cost of shipping is a factor. I managed to piece together an Icon Stage 2 kit for $1200 with prime shipping through Amazon. My friend at work had a set of Camburg UCA’s that he let go for $600. The Tundra originally came with Sw13 calipers, so off to Oreilly for the updated calipers and rotors (I brought my old Tacoma calipers for the core charge). After some wire wheels, degreaser, and raptor liner.
    Before:
    After:
    I did have to change out all tie rods, LBJ, and links/bushings. It appears previous owner had a failed LBJ some time in this trucks history as the drivers side wheel wheel and fender shows signs of a catastrophe
  3. Jun 13, 2023 at 2:10 PM
    boto_flea
    2002 Tundra 4wd
    With the front done, I put my womans to work with cleaning up the rear ;)
    Got the frame cleaned up, painted and the Icon shocks and progressive leafs installed.
    Thinking about flat bedding this one day so while the bed was off, I took some measurements of the frame for future reference.
  4. Jun 14, 2023 at 12:32 AM
    boto_flea
    2002 Tundra 4wd
    Took a break With the exterior and started working on some of the interior parts. Previous owner gauged the crap out of the dash trying to install an aftermarket stereo. Got the dash apart, patched up, and sanded smooth. Ready for primer.
    To windy to prime today, better luck tomorrow. Had some daylight left so me and the Mrs. started working on the headliner. Got all the old foam scraped off. Pic is me mocking up a switch panel I’m incorporating before laying down the new fabric.
  5. Jun 14, 2023 at 1:23 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Great work so far!
    boto_flea[OP] likes this.
  6. Jun 23, 2023 at 10:12 AM
    Brendanimals
    Brendanimals New Member
    Brendan
    York, PA
    2006 Tundra Double Cab SR5
    Eibach Pro Truck Sport Leveling Shocks - 3" 2.5" Blocks plus Sumo Springs (blue) in the back Nitto Terra Grappler G2 265/70/r17's K&N 57-9027 Cold Air Intake N-Fab Black Wheel To Wheel Nerf Bars Addco 2181 Rear Anti-Sway Bar
    Looks awesome - I plan to pull the bed and do a full frame painting this winter. You've re-inspired me with the look of this one.
  7. Jun 23, 2023 at 1:06 PM
    boto_flea
    2002 Tundra 4wd
    Removing the bed wasn’t too bad at all. I managed to get it off with just my wife. I lost two of the bed bolts due to heavy corrosion so you might want to keep that it mind. They tend to break off in the sleeve (mid way down the bolt shaft).
  8. Jun 23, 2023 at 1:13 PM
    Looks great. Always love seeing one brought back to life.
  9. Sep 16, 2023 at 1:11 AM
    boto_flea
    2002 Tundra 4wd
    Well, it’s been forever since I updated this. Finally got around to working on the Tundra.
    Got done sanding and painting some of the dash pieces. This is going to be my hunting/adventure rig so thought olive drab would look decent.
    I like the contrast in colors. The bottom half was painted in raptor liner hence the textured look and yes that’s a Lexus steering wheel from a GS300. Fits right into the splines no issues (so do the celica/Lexus IS)
  10. Dec 17, 2023 at 8:03 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Wait a sec...what’s that in her hand?....is she scrubbing the frame with a toothbrush?
