Tire poke question.
Discussion in 'Wheels & Tires' started by Badge618, Jun 7, 2023.
  1. Jun 7, 2023 at 11:09 AM
    Badge618
    Badge618 [OP] New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Wanting to have less tire poking out. Current poke picture attached. Current setup Fuel Maverick 20x9 +20 offset 5.75 bs Mazama Open Range 35x12.5. Looking at going to a Method 18x9 +18 offset 5.75 bs with a 34/35 tall 11.2/11.4 width tire. Should this setup get me closer to flush with the body? IMG_5577.jpg
  2. Jun 7, 2023 at 11:47 AM
    scs_vuth
    scs_vuth New Member
    Vuth
    Bay Area
    The short answer is NO. Both wheel are almost identical in specs. You'll end up getting the same result or in your case +2mm more wheel poke going with the Method 18x9 +18mm.
    Badge618[OP], Saltyhero13 and reywcms like this.
  3. Jun 7, 2023 at 3:29 PM
    Badge618
    Lassen County, Ca
    So if a go to a slightly narrower tire, what offset or backspacing should I be looking for to bring it all closer to flush?
  4. Jun 7, 2023 at 3:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    +50 ish
    PermaFrostTRD likes this.
  5. Jun 7, 2023 at 3:49 PM
    Badge618
    Lassen County, Ca
    Got it. Doesn’t seem to leave a lot of options.
  6. Jun 7, 2023 at 4:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No it doesn’t. Why do you want it tucked in more? It looks perfect now.
    BravoDeltaRomeo likes this.
  7. Jun 7, 2023 at 4:46 PM
    PermaFrostTRD
    Northern NY
    As stated prior I think you might not change much and maybe even poke some more with the 2nd setup. Look for an 18x8 wheel with 25mm to 50mm offset and the skinnier tire might get you where you want to be.
    joonbug and Saltyhero13 like this.
  8. Jun 7, 2023 at 6:00 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    This is +50mm offset, no spacers, and a 315mm tire width, which is pretty much dead on flush.
  9. Jun 7, 2023 at 6:06 PM
    Jarrow
    Jarrow New Member
    I put on rough country sport fender flares to cover up the poke from my SCS F5s, which are +12mm offset.
    Before:
    After:
  10. Jun 7, 2023 at 7:20 PM
    Badge618
    Lassen County, Ca
    Truck had bushwhacker flares when I bought it but don’t like the flares and the distance they poke out w/o the flares throws rocks against the truck.
    joonbug[QUOTED] likes this.
  11. Jun 11, 2023 at 3:30 PM
    Badge618
    Lassen County, Ca
  12. Jun 11, 2023 at 3:47 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes these will tuck in closer to stock.
    Stock wheels are +50 or +60 depending on the wheel. As the numbers go more negative the wheel pokes out more; more positive they tuck in more.
    Every 25.4 mm is 1 inch. So in your case going from +20 to +40 is about 3/4 of an inch tucking from where you are now.
    The tire width you plan to run also matters. Tires list their width based on the width of the rim they were measured on. In your case you shaved off about an inch from the tires you are currently running so you should be fine.
  13. Jun 11, 2023 at 3:48 PM
    Saltyhero13
    You can also punch in your numbers here:
  14. Jun 11, 2023 at 4:20 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I use wheel size and just plug in all the numbers
