Wiring diagram for instrument cluster? Digital clock malfunction
Discussion in '1st Gen Tundras (2000-2006)' started by Brennyl8r, Jun 11, 2023.
  1. Jun 11, 2023 at 11:43 AM
    Brennyl8r
    Brennyl8r [OP] New Member
    Brenny
    2000 trd
    My clock is shorting out or something. I blinks and tweaks out and time goes really fast. My battery also does way too quick if i leave my key on.
    Anyone know if a single one of these wires in the clips to the instrument panel is for the clock?
    I just want to try to eliminate that as a possibility.
    Yes i know there is probably a troubleshooting procedure for an electrical draw.
    but also i want to unplug the clock so i dont see the time slipping away at double speed anymore. It freaks me out.
  2. Jun 11, 2023 at 12:06 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  3. Jun 11, 2023 at 12:44 PM
    Integration Control and Panel is the basically the cluster of controls in the center dash, everything from the SRS passenger airbag switch/light to clock, 4WD buttons, etc.
    Integration Relay, similar in name but not function, is the in-dash fusebox. I know it's not listed here, but I'm tossing it out for sake of name similarity.
    It's worth noting, some have complained their radio won't turn on if the multi-wire connector on the back of the A/C and clock panel doesn't have power.
    These clocks don't last forever and sometimes have issues. They're not swappable. Even worse yet, the A/C control panel associated with comes in multiple formats and isn't plug-and-play as some may expect.
    1lowlife likes this.
  4. Jun 11, 2023 at 1:19 PM
    Brennyl8r
    Brenny
    2000 trd
    Yeah, I sort of figured that one of the many wires on one of those clips on the ac control panel went straight to the clock but looks like I could be wrong?
  5. Jun 11, 2023 at 1:39 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Yeah, the clock is part of the whole lower CCA.
    If you have a pik-a-part/junk yard semi close by, might keep an eye out for an early 1st Gen, which is a about all mine usually has....00-03
  6. Jun 11, 2023 at 2:46 PM
    We'd picked this guy apart in a previous thread. It looked impossible to swap the clock off, but if my memory is serving well - which is only the case about half the time these days - Toyota had a separate part number for the PCB it was attached to.
  7. Jun 11, 2023 at 3:18 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  8. Jun 11, 2023 at 4:39 PM
  9. Jun 12, 2023 at 8:36 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My girlfriends dad's 00 does the same thing with the clock, battery doesn't die though.
  10. Jun 13, 2023 at 9:29 AM
    bfunke
    bfunke Tundra Curmudgeon
    Might call circuit board medics in Greenville SC 8005472049
