2020 Tundra Battery (Need opinions)
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Jun 5, 2023.
  1. Jun 5, 2023 at 4:53 PM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    Hey all, so my 2020 Tundra finally is toast. I went to buy a new one but the store only had a 24F. I understand I need a 27F - 710cc battery.
    Does anyone have a brand recommendations? I haven’t replaced a battery in any vehicle of mine is veryyy long. Usually lease vehicles. Thanks for the help.
  2. Jun 5, 2023 at 4:59 PM
    AZCementTundra
    AZCementTundra Member
    AZ
    2018 TRD OR 4x4
    6112/5160, TRD (Dual Exhaust, Skid, Rear Sway), Durobumps, Rigid D-Series Pro, Talons Cat Skids, 275/70/18 KO2s
    Costco - interstate battery. Good price, 36 month no questions asked free replacement.
  3. Jun 5, 2023 at 5:04 PM
    AAA96
    It doesn’t appear that they make a 27F group AGM battery. Unless I am mistaken.
  4. Jun 5, 2023 at 5:47 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    No need for AGM, the trucks charging system was not designed to charge AGM. Save the money and buy a standard battery.
    ID-Matt, roxysdad, coldcanuk and 5 others like this.
  5. Jun 5, 2023 at 5:57 PM
    AAA96
    I am going to listen to you all. Wise decision. I’m going to go with the Interstate MTP-27F
    Leo's first and Joe333x[QUOTED] like this.
  6. Jun 5, 2023 at 6:53 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    When you go to interstate, tell them you want a 27f blem. Interstate battery with a blemished case. Only has 30 day warranty but it’s only $60.00. I change mine every three or four years. They put a sticker on it that says power charge if I remember right.
    bulldog93, coldcanuk and ATV25 like this.
  7. Jun 5, 2023 at 6:59 PM
    AAA96
    interesting. I guess it doesn’t hurt to ask. Is this something that’s an unusual deal or do all dealers knows of this?
  8. Jun 5, 2023 at 7:10 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I only go to my closest dealer but I’m guessing it’s the same at every one. They don’t always have blems of every size in stock. It’s hit or miss depending on which battery cases were molded imperfect. The last two I bought, they had multiples in stock. I also buy pallet Jack batteries that way and those are harder to get.
  9. Jun 5, 2023 at 7:18 PM
    Joe333x
    Joe333x Member
    Boston
    Guessing this is only for interstate locations and not costco
  10. Jun 6, 2023 at 3:27 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    That is correct.
  11. Jun 6, 2023 at 6:34 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I would go with AGM....Northstar, odyssey, XS, Optima.
    If you are worried about charging, you can add an HKB booster fuse to up your voltage and or throw a smart charger on it every once in a while.
    I went with a northstar 27f and its been great, i added the hkb booster, but there are plenty that dont even bother and work great. I've got quite the stereo, so it was a no brainer.
    reywcms likes this.
  12. Jun 7, 2023 at 3:39 PM
    Nubby
    Nubby New Member
    AZ
    2021 TRD Army Green
    This one seems to b popular as well..
    AZBoatHauler and WillTunBlack20 like this.
  13. Jun 7, 2023 at 4:12 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    If you are just using the truck like an average person, go to Costco or similar and get at 27F from Interstate. Don't over analyze the decision - go with good enough.
    If you are drawing extra power while not running from a fridge, lights, ham radio, etc or are winching, get an Odyssey AGM paired with a diode to increase the charging voltage of your system. Don't go AGM unless you have a true use for it - otherwise it's just wasted money.
  14. Jun 7, 2023 at 4:20 PM
    itsallgood101
    itsallgood101 New Member
    Randy
    Southern Utah
    2021 Tundra SR5 4X4 crew max
    I have a 2021 my battery went out. I went to the toyota dealer a hundred and fifty nine bucks out the door oem
    WILLINH and Grittytundra like this.
  15. Jun 7, 2023 at 4:23 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
  16. Jun 7, 2023 at 4:24 PM
    Joe333x
    Joe333x Member
    Boston
    A deep cycle battery is actually detrimental for starting your car, They will have less cranking amps but more amp hours.
  17. Jun 7, 2023 at 5:03 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    Seems like it should have been covered under warranty. Mine went out a week before the 36 mo warranty expired and it was replaced no charge.
  18. Jun 7, 2023 at 5:14 PM
    pursuit2550
    pursuit2550 New Member
    My 2020 battery went out and I just went to the dealer for warranty replacement. They say the dealer battery is better than the OEM battery from factory. Anyways do yourself a favor and buy a battery. They are all pretty much the same thing. There is like 3 main battery manful for all batteries, acid based. I have seen the black Interstate batteries come to my job with the sticker lop-sided. Basically a generic black shell and they slap whatever manuf label on it.
  19. Jun 7, 2023 at 5:50 PM
    itsallgood101
    Randy
    Southern Utah
    46k miles no deal
  20. Jun 7, 2023 at 6:43 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    I just needed my first new battery on my 2018 Looooooooooooong bed SR w/ 35k miles.
    Paid $130 to my local dealer for a 27f with a lifetime warranty.
  21. Jun 7, 2023 at 8:01 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I went with an AGM cranking battery in the boat for one only one reason. My battery is tucked under the console and I have to pull th battery out to check the water which is a PIA. AGM is maintenance free. Even though it is the same CCA as the previous flooded cell my motor does not seem to crank as hard. I would not go AGM in truck.
  22. Jun 7, 2023 at 8:49 PM
    mountainpete
    AGM makes sense there too because you can put it on its side for easier access. Good for consoles and cabinets.
  23. Jun 8, 2023 at 9:19 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    X2
    AndyTex, WillTunBlack20 and coldcanuk like this.
  24. Jun 8, 2023 at 5:45 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Any one using any of them lithium ion batteries?
  25. Jun 8, 2023 at 5:59 PM
    Joe333x
    Joe333x Member
    Boston
    AGM and lithium both have the same uses just lithium is lighter and can be discharged further. Neither meant for a starting battery, more for RVs, trolling motors and other uses where the battery is going to be used with a constant load discharging it and then recharged. Starting batteries are made to supply cranking amps to turn the engine over.
    WILLINH likes this.
  26. Jun 9, 2023 at 2:42 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Lithium batteries require special chargers and do not have the CCAs to function as starting batteries. Most people that use lithiums in boats only use them for trolling motors and electronics. There are a few companies that claim they make a lithium battery that can be used as a starting battery in boats.
  27. Jun 9, 2023 at 9:48 PM
    mountainpete
    My understanding and experience is different for AGM.
    AGM is a starting battery and by design can deliver 3x more starts than a conventional battery over its lifetime at the same or higher CCA for the size. They also have less of a voltage drop on starting load and faster recovery and charging times.
    Got to keep to seat heaters and digital displays running while your auto start stop activates and restarts the engine in traffic. It’s why many new vehicles that have traditional starters require AGM.
  28. Jun 9, 2023 at 10:24 PM
    Joe333x
    Joe333x Member
    Boston
    AGM batteries can definitely also be starter batteries, I put an Optima Yellow top in my Subaru in maybe 2017 then traded the Subaru for my Tundra and put the Yellow top in my sisters car in 2019 and that battery is still going strong. I completely understand the need for an AGM with start stop since you're drawing while not charging. Deep cycle AGMs are designed different than typical starting batteries though. I'm not an expert, just did a bunch of research and apparently the way plates are designed on deep cycle batteries, they are designed to be drawn from with a normal constant draw, and can be depleted and recharged without damage to the battery which is why they are used in solar power with RVs and trolling motors on a boat. While a normal starting battery in your car just needs to supply CCA to get the motor going and doesnt have much reserve capacity to be used when not being charged. I dont think its about what battery is better and more about application and use. If you are just putting a battery in your Tundra to be able to start it and drive it normally with out a bunch of added electronics and are not drawing from it while not running, than a normal battery is just fine. In a start stop vehicle where its going to be constantly drawn from without the engine running an AGM will definitely be a better choice, although disabling start stop is an even better choice in my opinion. I'm definitely not against AGM and have used them before and they do outlast a normal battery and dont require maintenance but at 2x to 3x the cost, unless you need it, it makes more sense to just use a normal battery and take care of it, by checking the water levels and plugging it into a charger once in awhile to top it off. I still have the stock battery in 2019 and plug it into my Optimate charger maybe once a month and its still going strong.
    WILLINH and Albino Predator like this.
  29. Jun 10, 2023 at 7:43 PM
    Albino Predator
    Albino Predator New Member
    2020 White Tundra
    I work for a battery company that makes Pb acid - Lithium batteries and other chemistries.
    1. There are differences in battery manufacturers, we are 100% compliant to CCA (90% compliance is BCI rule).
    2. AGM is good, but conventional Pb acid is better in hot engine bay, save your money.
    3. EFB is next generation, OE's are starting to use.
    4. Lithium starting is being used in some exotic applications in Europe.
    5. Lithium doesn't like extreme cold or hot/like your cell phone). Can't test CCA will not be possible at 0°F.
    6. Only handful of domestic (Clarios(JCI)/Intersys-NorthStar/EPM/Stryten(Exide) battery manufacturers, most are private labeled...Interstate made by Clarios/JCI
    7. Starting batteries are made for quick burst of energy, deep cycle batteries are made for longer draw, not recommended to interchange.
    8. Stick with OE, or a recognized national brand, most have reputation to manage.
    9. Local private brands are hit and miss, be careful, maker could change due cost.
    Hope this helps.
  30. Jun 19, 2025 at 3:41 PM
    Jodale
    Jodale New Member
    2020 Toyota Tundra TRD Pro
    Lesson #1 learned for my new 2020 Tundra. Duralast Gold battery will not work as the posts are on opposite ends and the cables are not long enough no matter which way you orient the battery.
