  1. Jun 9, 2023 at 12:23 PM
    #3451
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    What do you mean relief?
  2. Jun 9, 2023 at 12:30 PM
    #3452
    ziznack
    ziznack New Member
    Texas Y'all
    I get that. I kind of like the look, but to each their own. Either way, I hate the gloss black that doesn't really fit the scheme. The plastic matte black look fits much better. I'd hoped to do the wood grain, but I don't want it to look weird.
  3. Jun 9, 2023 at 12:40 PM
    #3453
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    Hell yeah!! I have the same color and ordered the Bumpershellz. Glad to see it looks great!!
    EC1 and digitalwiz like this.
  4. Jun 9, 2023 at 1:00 PM
    #3454
    ziznack
    ziznack New Member
    Texas Y'all
    Can you post the link to order?
  5. Jun 9, 2023 at 3:05 PM
    #3455
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Installed cellular router in truck today. I'll keep this post short, if you have questions ask away..
    Cellular router: Peplink CAT-7, 4G LTE (not 5G, no need for 5G in rural & outback, 4G LTE has better coverage anyway)
    Antennas: magnetic mount Abracon brand cellular
    Battery pack: 6000 mAh Lithium (keeps the router on for short engine stops and overnight usage)
    5v USB to 12 v converter: USB to 12v booster cable from Amazon (plugged into rear seat USB jack and charges the Lithium battery when engine is on)
    WiFi antennas: typical home router 2.4GHz WiFi antennas, used ones that are "proper" dipole design to get best range for the WiFi. This is very much overkill for use in the truck itself, but want to have WiFi coverage into camper being towed or parked nearby.
    Design goals: 1) Functional / works well for use in ID, NV outback; 2) Doesn't look too hillbilly; 3) Easy to remove leaving no trace.
    The only custom made part is a steel L bracket that is screwed into the edge of the front section of BAK MX4 tonneau cover. The mag mount antennas attach to those. The bracket is painted black. The hardest part was getting the two coax cables into the truck cab. Ran them through the vent in the back of the cab, the one between the cab and bed, with plastic flaps on the outside that flip open when a door is closed. (Someone on this forum suggested to NOT use that entrance, but I figured that only one flap is partly open due to the cables, so I did it anyways). The cellular router and battery are Velcro'd to the shelf below the right rear seat. Don't know why there is that plastic shelf there, but it came in handy and is just about the right size for this usage.
    I think most pictures are self explanatory, with the last one showing the two coax cables going through above mentioned cab vent...look in the middle of the picture to see the cables.
    Concerns:
    1) Will the stick on cable clamps hold long term.
    2) Will the coax cable vibrate and/or wear through on some friction point.
    3) The magnet on the Abracon cellular antennas is not as strong as I'm used to having for Ham magnetic antennas...hoping they don't blow off at 80mph when a semi passes. Might put bead of black Silicone around their base to more or less glue them down. But these cell antennas are pretty small by Ham standards, so it's probably OK as is.
    So how well does it work? In an outback location where we frequently go, hand held cell phones are useless and the Tundra built in cell/WiFi was quite marginal to the point of useless, this Peplink setup has consistent cell connection good enough to surf the web and upload pictures to Facebook with no problem.
    messages_0 - 2023-06-09T153741.315.jpg messages_0 - 2023-06-09T153744.321.jpg messages_0 - 2023-06-09T153748.356.jpg messages_0 - 2023-06-09T153751.791.jpg messages_0 - 2023-06-09T153755.246.jpg messages_0 - 2023-06-09T153758.832.jpg
    Caution techie: Being an RF antenna guy (40 years in that business) I struggled with what type of antennas and where to put them as getting good cellular signal is paramount in the outback. I went for an antenna that has good published radiation pattern and "efficiency", both of which are important. Ignore "gain" as that's a marketing number and is measured in only one direction. Put them outside of vehicle of course. Originally I tried to put them on the roof of cab, but routing the coax cable and risk of scratching the cab roof couldn't be overcome. In practice height above ground for such a mobile installation is not very important, with THE most important aspects being efficiency and secondarily a decent radiation pattern.
    A bit about the Peplink router: having never used one I was not sure what to expect. But wow, the Peplink software and hardware is fantastic and works very well. The only downside is that it literally takes 4 minutes to boot up and get a cell signal. Thus having it run on battery power to not turn off when the engine is off is very helpful.
    RatPanda and Henry1jg like this.
  6. Jun 9, 2023 at 5:45 PM
    #3456
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Got the windows, bed cover and taillights done this week.
    Man I love this truck.
  7. Jun 9, 2023 at 5:46 PM
    #3457
    Breathing Borla
    AZ
    Wow, is that legal, pulled over every 5 mins here , lol
  8. Jun 9, 2023 at 5:47 PM
    #3458
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Here's my two trucks, we'll one is, the tundra mine and the other I gave to my better half.
    Metro14536 likes this.
  9. Jun 9, 2023 at 5:49 PM
    #3459
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I've had it that way on my Chevy since day one, 8 years now and zero issues with inspections or the po po.
    I don't drink or drug so I really do give a shit if I get pulled over.
    Ya gotta admit thou she's sexy as hell!
    scarecrow87 and Henry1jg like this.
  10. Jun 9, 2023 at 7:12 PM
    #3460
    Texan-1794
    Texan-1794 New Member
    2023 Tundra 1794
    2023 Blueprint Tundra 1794 - Stock to the Bone!
    Boy, she must have really teed you off - a chevy! :lalala:
    gj953 and Blufin[QUOTED] like this.
  11. Jun 10, 2023 at 3:35 AM
    #3461
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Almost pulled the trigger on going to a 2023 Limited. Local dealer has 3 Limiteds on the lot. Trying to justify spending the money when my 18 is perfectly fine.
    I have noticed, however, that the trade value on the 2.5 gens has gone down significantly
    Metro14536 and (deleted member) like this.
  12. Jun 10, 2023 at 7:32 AM
    #3462
    ziznack
    ziznack New Member
    Texas Y'all
    They were all also artificially high mid 2022 until about March 2023 because of supply on the new ones. It caused new ones to be sold way over MSRP and used ones to sell higher as well.
  13. Jun 10, 2023 at 8:18 AM
    #3463
    bombsquad85
    bombsquad85 New Member
    2023 Tundra Limited Blueprint
    Just got mine on Thursday I'm in love. Went from a 21 Hyundai sonata lol what a POS that was. I got myself a 23 limited crew cab in Blueprint.
    Metro14536, Blufin, Boerseun and 7 others like this.
  14. Jun 10, 2023 at 8:33 AM
    #3464
    Cj6530
    Cj6530 New Member
    2023 Black Limited
    What running boards are those?
  15. Jun 10, 2023 at 8:34 AM
    #3465
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    i know everyone has the same question: What is your MPG with those 40's? ;) Any handling issues over 80 MPH?
    gmcguire7220 likes this.
  16. Jun 10, 2023 at 2:22 PM
    #3466
    Hugh_Jaynus
    Hugh_Jaynus New Member
    2023 Silver Tundra Platinum 4x4 Crewmax
    Front windows tinted to match the back.
  17. Jun 10, 2023 at 3:34 PM
    #3467
    Joemh711
    Joemh711 New Member
    Joe
    2013 Crewmax Texas Edition-Sold, 2015 Red TSS Crewmax-Sold, 2020 TRD Sport Crewmax-Sold, 2023 Tundra TRD Pro
    Finally installed the Wildpeak 35x12.5r18s today . Can confirm that on 2023 TRD Pro no rub at all and still plenty of space . Truck looks much better . I removed mud flap before install so can’t say if it works with it . But have seen a 22 TRD Pro still have the metal bracket behind the liner, however on mine the 23 pro does not have that metal bracket behind the liner . Just a heads up
  18. Jun 10, 2023 at 4:08 PM
    #3468
    ziznack
    ziznack New Member
    Texas Y'all
    So I put new wheels on my truck. They said they were not able to use the tpms sensors on the new wheels. But they could not program the new sensors to the truck. Something about their software only going to 2020. Thoughts/ suggestions?
  19. Jun 10, 2023 at 4:12 PM
    #3469
    Breathing Borla
    AZ
    who is they?
    discount tire does this stuff like clockwork if you have one near
    Buildn likes this.
  20. Jun 10, 2023 at 4:14 PM
    #3470
    ziznack
    ziznack New Member
    Texas Y'all
    Drivers edge. It's a tire place we go to near us. Yeah there is a discount. I will call them and see. It just sucks cause I'm assuming they will charge me. Not sure why they couldn't use the sensors that were in there.
  21. Jun 10, 2023 at 4:15 PM
    #3471
    Breathing Borla
    AZ
    Ya give discount a call, even if it’s a couple bucks , do it once, do it right and roll on
  22. Jun 10, 2023 at 4:15 PM
    #3472
    bombsquad85
    Lol I'm not sure they were on the truck from the factory. I'll see what the window sticker says when I have a chance
  23. Jun 10, 2023 at 4:16 PM
    #3473
    bombsquad85
    I really like it. It wasn't one of my top choices, but when I saw it in person I couldn't pass it up.
  24. Jun 10, 2023 at 4:21 PM
    #3474
    ziznack
    ziznack New Member
    Texas Y'all
    Yeah agreed. Thanks. Any clue why they would not have been able to use the OEM sensors? They said something about the valve stem in the new wheels was just a rubber one. Maybe they were just lazy and didn't want to take the wheel apart and get them out?
  25. Jun 10, 2023 at 4:22 PM
    #3475
    ziznack
    ziznack New Member
    Texas Y'all
    They really should just let you get these wheels with the 1794, or let you get the interior on the platinum.
    Tundrastruck91 likes this.
  26. Jun 10, 2023 at 4:25 PM
    #3476
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Gave it a bath! Then it rained on it about 2 hours later.
  27. Jun 10, 2023 at 4:36 PM
    #3477
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I’d get a 2023 if you can swing it.
    I was hesitant like you last June when I had my perfectly fine 2017 SR5 TRD with 85,000 miles and paid off. My friend wanted my 2017 because his Tacoma struggled to pull his camper. I’m glad I pulled the trigger on a 2022 Limited. This truck is completely different than the 2.5 generation. It’s quicker, handles superbly on tight curves, lots of safety features and way better mpg. I’m going in for my 15,000 Mile service on Monday and on the highway at 72-75 mph I’m averaging 20 mpg. On my 2017 I was getting 17 at best.
  28. Jun 10, 2023 at 4:53 PM
    #3478
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    I got my go rhino rb30 boards mounted up. I also got my RC 1.75" front and cornfed 1" rear spacer installed.
    This is a temporary setup until I pull the trigger on dobinsons.
  29. Jun 10, 2023 at 6:31 PM
    #3479
    TFTJ
    TFTJ New Member
  30. Jun 10, 2023 at 6:39 PM
    #3480
    ziznack
    ziznack New Member
    Texas Y'all
    Yeah I ended up buying the matte black one today.
