Shock Mount Bolt Stuck. HELP!
Discussion in 'Suspension' started by nlwarren, Jun 10, 2023.
  1. Jun 10, 2023 at 3:13 PM
    nlwarren
    nlwarren [OP] New Member
    2005 Toyota Tundra - Double Cab
    Hi all,
    I'm replacing the suspension on my 2005 Tundra DC. Everything was going smoothly, until I went to remove the original shock/coilover assembly. The three nuts at the top came off no problem. The mounting bolt at the bottom will not budge. I've tried a puller and impact wrench, a mini-sledge, and then a full size sledge. I've also tried putting some back pressure on the hub to see if it would relieve a pinch point. I believe I've now ruined the bolt trying to beat it out so I'll order a new one this afternoon.
    What am I doing wrong? In all of the suspension swap videos I have watched, I've never seen anyone struggle with this. Especially surprised as this truck is almost completely rust free and other bolts are coming out easily.
    Please help!!
    Thanks,
    Noah
  2. Jun 10, 2023 at 3:15 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    pressure
    Sometimes a Jack under the control arm will reduce pressure on the bolt.
    other times heat is the answer
  3. Jun 10, 2023 at 3:20 PM
    nlwarren
    @ZappBrannigan , thanks. I hadn't thought about heat, I'll try that. At this point I have the top of the strut completely off, so there should be no pressure except for the weight of the strut and spring on the mounting bolt.
  4. Jun 10, 2023 at 3:48 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well, let us know how it works out.
  5. Jun 10, 2023 at 3:49 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Is the shock flopped to the side creating pressure on the bolt?
  6. Jun 10, 2023 at 3:49 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Can you spin the bolt? When they don't budge like that its usually due to the bolt rusting/bonding to the metal insert in the shock.
  7. Jun 12, 2023 at 12:07 PM
    nlwarren
    @TILLY that's exactly what happened. So I tried everything under the sun, including the heat recommendation at different heats, letting it fully cool overnight, and trying again with higher heat.
    Nothing worked. Cut it out with an angle grinder, bolt was seized to insert. I ruined the strut mounts in the process of banging and cutting, so I've no ordered a new lower control arm from Moog. Bummer...
    TILLY likes this.
  8. Jun 12, 2023 at 2:04 PM
    TILLY
    Massachusetts
    Glad you got it straightened out, except for the destruction part of course. :thumbsup:
  9. Jun 12, 2023 at 2:13 PM
    blenton
    blenton New Member
    Bummer. But glad you got it figured. I had a bolt seize in my rear shackles; luckily it was the shackle to spring bolt and not the shackle to frame bolt. I was able to pull the springs with the shackle still attached but even out of the vehicle I had zero luck freeing it, using all of the methods you mentioned above. So that CoachBuilder shackle is permanently attached to the spring waiting to go the recycler. Luckily, I kept my stock shackles and through those back in.
