Seal skin car cover for hail? Experiences?
Discussion in 'General Tundra Discussion' started by Boxerdog, Jun 6, 2023.
  1. Jun 6, 2023 at 5:01 PM
    Boxerdog
    Boxerdog [OP] New Member
  2. Jun 6, 2023 at 6:14 PM
    Never heard of them before and they are about 45 minutes away.
  3. Jun 9, 2023 at 9:13 AM
    DeanoBambino64
    DeanoBambino64 New Member
    Dean
    Saskatoon Area
    2008 Tundra Crewmax Limited 4X4 5.7L V8, 20"aluminium oem wheels.
  4. Jun 9, 2023 at 10:10 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I don't see how any type of fabric would protect from impact damage, unless it's wrapped over a frame and suspended above the surface of the vehicle.
    Even if it's the toughest fabric there is, if it's right against the sheet metal and something large enough to make a dent or crack glass hits it, it's still going to make a dent or crack glass.
    Does it have some type of impact absorbing layer of foam or something?
    rodm1 likes this.
  5. Jun 10, 2023 at 2:46 PM
    rodm1
    rodm1 New Member
    I would glue foam to plywood then ratchet strap it to the truck then throw a cover over that. Make the panel the profile of the truck maybe study damage photos to figure what panels are needed.
  6. Jun 10, 2023 at 3:03 PM
    2mchfun
    Plant posts around your parking area and buy a shade sail to put up with bungees on two sides so it can stretch during heavy winds. Hail will not penetrate it. The only downside is that you have to be home. That said, when I begin to live out of my truck and trailer I plan to build a system that will attach directly to my truck to protect against hail. Just park, quickly assemble in 15 minutes and remove after the storm. Not practical for everyone though. If you don't care about the paint too much, old carpet turned upside down works well. Then just discard and replace. Obviously, storage and paint scratches are issues. Good luck with your decisions.
