Eibach Stage 1/Stage 2 heights & best place to buy?
Discussion in 'Suspension' started by Jeremy323, Feb 22, 2023.
  1. May 24, 2023 at 11:40 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I don't personally run them, but have sold plenty of these kits and other suspensions over the years. As long as you don't go over 2" of front lift you should be able to get away with stock UCAs still getting you back into alignment spec. :thumbsup:
    radon222[QUOTED] likes this.
  2. Jun 10, 2023 at 8:10 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    @memario1214 do you recommend changing out the bump stops with the Eibach stage 2?
  3. Jun 10, 2023 at 9:37 AM
    memario1214
    Colton
    Missoula, MT
    Do you “need” them? No. You don’t have any shock lengths too long to where flattening a shock is a concern on these kits. Are they a quality of life improvement if you’re in rough enough stuff to be striking them? Absolutely.
  4. Jun 10, 2023 at 10:37 AM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I have been thinking of this. What do you have and/or recommend?
  5. Jun 10, 2023 at 11:07 AM
    memario1214
    Colton
    Missoula, MT
    We run Durobumps on our Tundra, and have been happy with them. Once you get to the quality stuff, it’s all pretty similar. We run Timbrens on our F150 and the quality is similar. Lots of options, but I personally prefer the dual-Durometer rubber of the Durobumps.
    https://hotshotoffroad.com/products/front-bump-stops-07-21-tundra
    https://hotshotoffroad.com/products/rear-bump-stops-07-21-tundra
