How many hits will the oem skid plate take?
Discussion in '2.5 Gen Tundras (2014-2021)' started by StarLord, Jun 8, 2023.
  1. Jun 8, 2023 at 4:25 AM
    StarLord
    StarLord [OP] New Member
    jake
    18’ Tundra Platinum/ 20’ TRD Pro Sequoia
    . . . . . Exactly one!
    I have decided to answer the age old question for everyone via self sacrifice and sending it one last time before throwing on the RCI’s. Yup, you get one good hit and that’s it.
    PSA: it’s a pain to take off once it’s at this point.
  2. Jun 8, 2023 at 5:15 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Dang. What did you hit?
  3. Jun 8, 2023 at 5:21 AM
    StarLord
    jake
    I just bottomed out with a poor approach angle moving way to fast crossing a gully/ditch. Was clay/rock.
    BrandonL812 likes this.
  4. Jun 8, 2023 at 5:38 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Not surprised. The stock plate is patheticly thin.
  5. Jun 9, 2023 at 4:33 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I bent my plate up when bottoming out on my brothers crappy road to his place in the northern Minneasota woods. Good excuese to buy the RCI plate, almost worth it for ease of oil changes alone.
    StarLord[OP] and Johnmatrix like this.
  6. Jun 9, 2023 at 5:58 AM
    Jeepin48
    Jeepin48 New Member
    Jake
    2019 TRD Sport
    Is the thicker RCI skid going to cause any risk of bending something more sever (frame cross member) because it is more robust?
  7. Jun 9, 2023 at 10:59 AM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    I bent my stock plate the first time out. Looked close to the OP’s.
    Diving slowly on a pot holed section of dirt road. The left and right wheels dropped into pot holes and the skid hit level ground, hard. Stopped the truck dead in its tracks.
    I too thought it’s meant to bend easily to save other parts of the truck.
    I just hammered it back to shape enough so bolt holes would align. Good to go.
  8. Jun 9, 2023 at 11:45 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Dayumm!! That must've been a cringe-worthy noise.
  9. Jun 9, 2023 at 12:43 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    The stock skid plate is just a dust collector. One time use!
    StarLord[OP] likes this.
  10. Jun 9, 2023 at 12:53 PM
    SD Surfer
    Bruce
    So Cal
    Kinda' like those disposable roasting pans... Yes, technically they're made of metal, and yes you can roast a bird in 'em, but then they're done. :rolleyes:
  11. Jun 9, 2023 at 2:42 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Somewhere between 0 and 1.
  12. Jun 10, 2023 at 7:46 AM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    How many licks does it get to the center of a Tootsie Pop?
    Riddle me this and you will be on the path to enlightenment.
    StarLord[OP] and FrenchToasty like this.
  13. Jun 10, 2023 at 8:52 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I have found that the gas and transmission crossmembers have held up pretty well to my abuse. Engine crossmembers are pretty much bulletproof. Unless you’re sending it then forget about it.
