Nitto Recon Grappler
Discussion in 'Wheels & Tires' started by PermaFrostTRD, Jun 9, 2023.
  1. Jun 9, 2023 at 7:16 PM
    PermaFrostTRD
    PermaFrostTRD [OP] Tumescent Member
    Northern NY
    Haven’t seen a specific/dedicated thread so I figured I’d start one.
    I’ve had mine a week so far. About 120 miles on them. 285/70r18 on stock TRD OR wheels. Been dry as the Gobi for the whole week until tonight. Put the truck on the highway at about 67-72mph and then we got about 10 minutes of a frog strangler while on the highway.
    Truck did great on the highway and tracked like a dang sled in the 1-2” of standing water on the interstate. I slowed down to 45-50 during the deluge and it just held. Pretty happy with the performance and looking forward to some snow performance reports.
    These fared better than my 275/70r18 KO2’s and 295/70r18 Baja boss AT (on my 2014 DC). The bajas felt pretty “floaty” vs these recon grapplers but I feel like width could have played a part
    feel free to share your experiences good or bad.
    scruffy727 likes this.
  2. Jun 9, 2023 at 7:22 PM
    PermaFrostTRD
    Northern NY
    Well crap. Turns out there are a couple of other threads on these. My bad. Feel free to merge if you want mods. :facepalm:
  3. Jul 22, 2023 at 8:21 AM
    scruffy727
    scruffy727 New Member
    Rob
    Ventura County, CA
    2020 SSM Platinum 4x4
    TRD Dual Exhaust TRD Rear Stabilizer Color-Keyed Mirror Caps Amp Research Bed Extender BedRug XLT Toyota Power Tailgate Lock Extang Xceed Tonneau Cover CarPlay 2 Air
    Do you have pics? I am considering the same tires in this size on my 2020.
    PermaFrostTRD[OP] likes this.
  4. Jul 22, 2023 at 10:14 AM
    Just an FYI....the Ridge Grapplers have a higher wet traction rating than the Recon Grapplers. If you want the best wet traction for a large tire, the Toyo AT3 is the highest rated.
  5. Jul 22, 2023 at 10:56 AM
    Nickels9
    Nickels9 New Member
    Eric
    Tucson, Az
    2016 Crewmax
    Just picked up Ridge Grapplers for my 16 Crewmax, haven’t had them in the rain yet but they look great on my XD Monster wheels
  6. Jul 24, 2023 at 4:06 AM
    PermaFrostTRD
    Northern NY
    Sure do.
    In its natural habitat:
    dpast88 and Leo's first like this.
  7. Jul 28, 2023 at 2:01 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    How do they feel on wet road stop & go? I saw a review somewhere guy saying he thought it spun too easily taking off from stop on wet roads compared to his old tires.
  8. Jul 28, 2023 at 2:46 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Dayumm, that looks gooood! :goingcrazy:How much is your front raised? 6112's, Coilovers, what?
  9. Jul 29, 2023 at 4:41 AM
    PermaFrostTRD
    Northern NY
    Thanks man I really like the stance, performance, and appearance.
    I lifted the front end only. Falcon coil overs use the stock spring, and it has 3 settings: low, med, high which corresponds to 0” lift, 1” lift, and 2-2.25” lift respectively. I set mine on the medium which is at 1”.
    I’ve never run bilstein 5100’s or 6112’s up front so I can’t compare to those but I’ve read that they can be rather stiff :confused: - again I can’t comment from experience on that but didn’t want to find out and have to “upgrade” again. My 2014 had fox 2.0 coil overs set at 2” and this feels very similar in terms of a nice stable smooth ride. Doesn’t dip on turns and absorbs crappy roads and the occasional off road I do. I am also running 5100’s in the rear without blocks or any lift back there. Feels firmer but not jarring if that makes sense.
    SD Surfer[QUOTED] likes this.
  10. Jul 29, 2023 at 4:46 AM
    PermaFrostTRD
    Northern NY
    They feel very safe and have yet to slip. But they’re brand new, I’m not supercharged, and I’m not 16 years old trying to impress a cheerleader.
    Totmacher[QUOTED] likes this.
  11. Aug 9, 2023 at 11:39 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Had my SCS wheels removed today from my tire guy he had the new Falken wildpeaks R/T trails on the show room floor. The tread and sidewall look great on them.
  12. Sep 2, 2023 at 3:05 PM
    iceburg
    iceburg New Member
    2018 CM 5.7
    none yet
    What tire pressure you running with your Ridge Grapplers. 285/70R18. ?
  13. Sep 2, 2023 at 3:09 PM
    RusPro21
    Don
    Pa.
    If you were asking me my Grapplers were 10 ply 285’s and ran 45 lbs all around. I like how they road and handled at that pressure.
  14. Sep 2, 2023 at 3:22 PM
    iceburg
    iceburg New Member
    2018 CM 5.7
    none yet
    Tire shop wanted to put 35psi. Told him that was to low. LT 285/70R18. 127/124Q. 10 P.R. Sidewall says 80 psi. I'm figuring 44psi. Just curious what everyone else was running. My tundra is 2018 sr5 crewmax.
    PermaFrostTRD[OP] and RusPro21 like this.
  15. Sep 27, 2023 at 12:27 PM
    csgaddy
    csgaddy New Member
    what size tires are you running on your setup?
  16. Sep 27, 2023 at 2:23 PM
    iceburg
    iceburg New Member
    2018 CM 5.7
    none yet
    285/70R18.. nitto got back to me...33psi in front. 35 in rear.
  17. Sep 28, 2023 at 3:19 AM
    PermaFrostTRD
    Northern NY
    First post in the thread.
    285/70 r18
