2023 Tundra 1794 Ed - Driver Side Window Rattle
Discussion in '3rd Gen Tundras (2022+)' started by CCOMP83, May 22, 2023.
  1. May 22, 2023 at 11:36 AM
    CCOMP83
    CCOMP83 [OP] New Member
    2023 Tundra 1794
    None
    The driver side window on my 2023 Tundra rattles loud when rolled down and if I have music playing. With the amount of money I paid for the truck I would not expect this, so I took it to the dealership for them to look at and was told that the window was installed correctly and that they couldnt do anything unless there was a recall on this (other owners experiencing the same issue).
    Is anyone else having this problem? it feels like poor quality for this rattle to occur.
    thank you!
  2. May 22, 2023 at 5:38 PM
    WoodyOne
    WoodyOne New Member
    Spring, TX
    2023 1794 Blueprint 4x4
    No problems with mine, although I do have some rattling in various places with strong base from the JBL
  3. May 23, 2023 at 4:28 PM
    CCOMP83
    2023 Tundra 1794
    None
    @ryanwgregg i was able to narrow it down because when i was sitting in the driver seat and turn up the music its very noticeable. I took it to the dealership and didnt have much luck getting any answers. Im not sure if they created a TAS Case or not....
    @WoodyOne yes thats exactly my issue is the bass from the speakers is rattling the windshield when its seated in the door panel. its really noticeable and irritating because it sounds like some cheap teenager who is trying to bump his music but his cheap truck is rattling when the bass hits and its annoying especially since the amount of $$ i spent on the truck.
  4. May 23, 2023 at 4:55 PM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    wait... do you mean drivers side window? Or is the actual drivers side of you windshield rattling??
  5. May 23, 2023 at 5:33 PM
    CCOMP83
    2023 Tundra 1794
    None
    @trazerr drivers side window. Sorry i just realized i did put "windshield" which makes it look like the front windshield. the drivers side window rattles when its rolled down and the bass hits.
    ryanwgregg and trazerr like this.
  6. May 23, 2023 at 5:34 PM
    Hella Krusty
    Hella Krusty New Member
    What does the windshield have to do with the drivers door window ???
  7. May 23, 2023 at 5:48 PM
    CCOMP83
    2023 Tundra 1794
    None
    @Hella Krusty nothing sir. It was my mistake as i stated above in this thread. I meant just the driver side window. I will go back and correct it.
    Hella Krusty and ryanwgregg like this.
  8. May 23, 2023 at 7:41 PM
    WoodyOne
    WoodyOne New Member
    Spring, TX
    @CCOMP83, I think I read somewhere that removing the foam in the driver's door handle helps the rattle. I will see if I can find that post. Mine is not bad, so I have not tried.
    Edit:
    Could not find anything about removing foam but here is a thread on the door rattle and various fixes, if you have not already seen it.
    https://www.tundras.com/threads/passenger-front-door-rattle.108757/
    Tundrastruck91 likes this.
  9. May 25, 2023 at 6:17 AM
    CCOMP83
    2023 Tundra 1794
    None
    @WoodyOne thank you for sharing that thread link!!! sounds like there is a bunch of people with that same problem. I am still working through all the comments. Just wanted to give you a shout out for the help
    WoodyOne likes this.
  10. Jun 9, 2023 at 9:15 AM
    Harmacist
    Harmacist New Member
    Alex
    NC
    2023 MGM 1794 TRD OR
    I just noticed this issue yesterday. I found a quick way that I can keep it from rattling. If I drop the window all the way, then just quick pull up on the button so it’s not all the way down but isn’t high enough to clear the rubber, then the rattling stops. Mine is so minor I only notice it when stopped and with the right bass tones.
