What size wire would you use
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, Jun 8, 2023.
  1. Jun 8, 2023 at 7:01 PM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    So I’m getting ready to do my rear speaker install and was mocking up the power outlet install for the rear doors while I had it all apart. My question for the experts is what size wire would you pull to feed these outlet(s)?
    So with some googling, it looks a dual outlet phone charge can pull up to 4.8 amps if both slots are in use. I like to overkill my stuff like we do on powerlines. So I figure 4.8x3 = 14.4 amps which puts me at the high end of 14awg. I don’t think these outlets will see that much load but idk. Or am I way off here, overthinking it or what ? Then again I could pull each an outlet a dedicated run instead of daisy chaining? Plan is to pull off a spare circuit in the interior fuse panel, like the sun roof or heated seats fuse slot (my truck has neither). I figured I’ll be in the doors for the speaker install might as well do this while I’m at it
    * on a side note, how come nobody does component speakers in the rear of these trucks? Is it because nobody wants to custom mount tweeters?
    @shifty` @assassin10000 @bmf4069
    thanks in advance fellas
    JasonC. likes this.
  2. Jun 8, 2023 at 7:20 PM
    I'd be comfortable with 14awg. 12awg is a hell of a lot to stuff thru the door. I wouldn't be surprised to see OEM was using 18awg for the power ports.
    1lowlife, Cummins3500[OP] and JasonC. like this.
  3. Jun 8, 2023 at 7:31 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Depends. How much are you really gonna pull through that lighter adapter?
    I'm leaning towards 12ga.
    Cummins3500[OP] and des2mtn like this.
  4. Jun 8, 2023 at 7:35 PM
    Oh - that actually brings up a good point. Are you running a separate wire for each power port, which is what I interpreted? Or are you talking about pulling one in, then forking it?
    Cummins3500[OP] likes this.
  5. Jun 8, 2023 at 7:52 PM
    14 is actually good for 20A. It's limited to 15 for the NEC. You're not supposed to go above 80% for wire ampacity, so that's 16A. I vote 14AWG.
  6. Jun 8, 2023 at 8:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Just make sure you are fused properly, which a larger wire (like 14 ga) should be fine with. You want your fuse to fail before burning a wire up.
  7. Jun 9, 2023 at 4:16 AM
    Cummins3500
    Logan
    i figure cigarette lighter plug will rarely if ever get used. At the most it might see a small plug in inventor. But I figure my kids will mostly be using the usb ports.
    the math I did above was figured on pulling one wire tied to the 2 outlets but after so more googling looks like I need to pull a separate wire for each outlet
    @shifty` @bmf4069 @Bakershack @assassin10000 , appreciate the guidance
    bmf4069 likes this.
  8. Jun 9, 2023 at 4:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    For pure copper not copper clad aluminum
    shifty` and FrenchToasty like this.
  9. Jun 9, 2023 at 4:21 AM
    One wire to both would be fine.
  10. Jun 9, 2023 at 4:24 AM
    I'm very confused by this chart...
  11. Jun 9, 2023 at 4:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It's the rainbow affect or wrong coffee brand.
  12. Jun 9, 2023 at 4:32 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Years ago a ran the maintenance crew at a factory. I was interviewing candidates for maintenance/handyman position, and I still am amused by this one guy's response. I posed a hypothetical question: "let's say we're building out a new office space, using a lighting grid of 6 fluorescent fixtures, each with 4x48" bulbs...what kind of wire would you use?" I was expecting responses like: "can we use Romex in a commercial building?", or "is it a 408 volt grid?", or virtually any other response indicating that his brain was engaged, and that he had sufficient experience to solve the problem. He carefully considered the question, and after several moments of apparently deep thought he responded..."I'd use 'lectric wire, of course". (As opposed to barbed wire, or maybe bailing wire I guess). He didn't get the job.
  13. Jun 9, 2023 at 5:30 AM
    That’s a shame. He wasn’t wrong. And common sense isn’t that common anymore.
    bmf4069, Cummins3500[OP] and shifty` like this.
