2023 Platinum
Discussion in '3rd Gen Tundras (2022+)' started by Hunter1699, Jun 8, 2023.
  1. Jun 8, 2023 at 10:33 AM
    Hunter1699
    Hunter1699 [OP] New Member
    So I bought a 23 Platinum and is still at the dealer since I requested to have a Rough Country level installed prior to delivery. It has AVS and bags on the rear. I requested this due to the research on this forum indicating it has been done. Dealer says can't be done and just to get my truck told them I would have it done somewhere else.
    I would just like to confirm one more time thru you guys that I can get it done after the fact and if you can provide photos. Thanks for any info you can provide.
  2. Jun 8, 2023 at 10:39 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Roughy country lift huh? Congratulations on your inevitable cv joint failure . Take this as a sign to not do it
  3. Jun 8, 2023 at 11:31 AM
    dodgemaniac
    dodgemaniac New Member
  4. Jun 8, 2023 at 12:48 PM
    Breathing Borla
    AZ
    ya this, don't buy a AVS truck and put a shitty lift on it, the AVS ride is awesome
  5. Jun 8, 2023 at 4:45 PM
    Hunter1699
    I hear you all. Obviously the level kits can be done but at the sacrifice of AVS capabilities. Just want to put on bigger and more aggressive tires on the stock rims. Anyone know the biggest tire I can put on without a level? Fully understand what the larger tires will do to ride/mileage. Was planning Nitto Recon Grappler 35x11.5x20.
  6. Jun 8, 2023 at 6:27 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    These guys get triggered with the “What’s the biggest tire I can go” question….
    Good luck!
    Yaboy, Patch999 and Hunter1699[OP] like this.
  7. Jun 8, 2023 at 6:39 PM
    Hunter1699
    Yes sir I got it. I have been monitoring forum foe a long time. Just finally pulled the trigger on new ride. Not a total noob. Had my 07 since new and actually wasn't looking for the Platinum but could find exactly what I wanted but definitely got more I need. Just hoping someone with like truck on OEM wheels could shoot me a quick response.
    Patch999 likes this.
  8. Jun 8, 2023 at 6:45 PM
    Taco-Spike
    Two Trucks
  9. Jun 8, 2023 at 8:51 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    If you want to do the lift and modify suspension, why are you even buying truck with AVS???
    There's plenty of inventory available now and you should be able to find whatever you want, such as no AVS, no Trd Tundra with regular suspension and install any kit on it.
