2007 Tundra Brake short
Discussion in '2nd Gen Tundras (2007-2013)' started by Jablippy, Jun 8, 2023.
  1. Jun 8, 2023 at 8:50 AM
    Jablippy
    Jablippy [OP] New Member
    2007 Tundra 5.7L
    My 2007 has a short somewhere in the Stop wire circuit. The STOP fuse blows almost immediately when the brake is applied. Checked all of the obvious things with no luck. Funny thing is, the starter fires up for a split second when I apply the brake before the fuse blows. I'm stumped at this point, and any suggestions would be greatly appreciated.
  2. Jun 8, 2023 at 8:59 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check your ground points. Kick panel driver side would be my first check. Make sure the grounds there are good. 2nd one may be rodent dropping or damage to your wiring someway somehow.
