Transmission filter ?????
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lemuel1, Jun 5, 2023.
  1. Jun 5, 2023 at 5:39 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Ordered a trans cooler and 12 quarts of amsoil tranny fluid. Is a filter worth it ? 45k on truck towed light twice no idea how it was treat previously. I got it at 28k miles a year ago. Mostly highway in the year I’ve had it.
  2. Jun 5, 2023 at 5:43 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  3. Jun 5, 2023 at 5:52 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
  4. Jun 5, 2023 at 5:57 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Potato. Potata.
    I just did a drain (3,850ml) and fill at 92,500 miles. Like many on this board the tranny fluid wasn't burnt. A dark purple in color. I don't tow.
    I don't think it necessary for you yet. Others will remind you tranny fluid is cheap and a tranny is expensive.
    Lemuel1[QUOTED][OP] likes this.
  5. Jun 5, 2023 at 5:57 PM
    Joe333x
    Joe333x Member
    Boston
    You can see what I had in my filter in that thread. I would say you could probably never replace it and not have a problem. Unless you know you can get those bolts out, I wouldn't risk it. Getting the broken bolt out was a headache.
    2mchfun likes this.
  6. Jun 5, 2023 at 6:04 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    Hmm indeed drain and fill it is. Thanks for the help.
    2mchfun and Joe333x[QUOTED] like this.
  7. Jun 6, 2023 at 8:45 AM
    2mchfun
    X2 for drain and fill only
    Lemuel1[OP] likes this.
  8. Jun 6, 2023 at 9:18 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    skip the filter, in normal circumstances I dont think it ever needs to be replaced, its just a strainer. drain and fill every 30-60k and your golden.
  9. Jun 6, 2023 at 10:34 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    Sold not doing it then. Hopefully my fluid isn’t too terrible at 45k.
  10. Jun 6, 2023 at 10:37 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Good call. I D&R every 30-50K, at 170K now. I did change the filter recently because I had to drop the pan to change out a shift solenoid. I didn't cut it open, but with a flashlight, I didn't see ANY debris on it.
  11. Jun 6, 2023 at 10:47 AM
    Joe333x
    Joe333x Member
    Boston
    The way it's designed you'd actually have to cut it open to see any debris cuz it gets trapped in like a bag inside the plastic housing. Curious what the symptoms were that required you to change the solenoid how you knew which one that needed to be replaced.
  12. Jun 6, 2023 at 11:29 AM
    VWTim
    Corvallis, OR
    The dash went full circus light and it it triggered a S4 shift solenoid high? resistance code. Then the truck went into limp mode w/o 5-6 gears. I was able to reset the code and manually cycle the solenoid via Techstream and it worked for a couple weeks, then it did it all over. Changed the solenoid and it's been solid for 6,000 miles.
    Joe333x[QUOTED] likes this.
  13. Jun 6, 2023 at 5:42 PM
    Joe333x
    Joe333x Member
    Boston
    Thanks for the info, I also have Techstream, what did you have to do to manually cycle the solenoid?
